Sony Playstation 3 (PS3) Console Logo
Anonymous Posted on Nov 03, 2009
PS3 WILL play games but NOT Blu-ray or regular DVDs
My PS3 WILL load my games and I can play them but NOT any Blu-Ray or regular DVD's nor will the PS3 main screen open up. And, it will only load the games when I already have the disc in the PS3, start it up, eject the disc, and then re-slide the disc back in?? Since the main screen won't come up I can't download any new updates...
I've tried buying a new Monster HDMI cord and using a different input on my reciever, but it still won't play movies. I have also tried hooking it up directly to my HDTV and it still doesn't play movies, just the games.
With my hookup, I have everything routed thru my Onkyo reciever, the PS3, my HDTV and DirectTV; which the later two are working fine.
Anonymous
Level 3:
  • Master 317 Answers
  • Posted on Nov 03, 2009
Anonymous
Master
Level 3:
Answers
317
Questions
Helped
98980
Points
1237
Hold the power button down when it is red till you hear the quick beeps then select the file restore. this is a diagnostics screen...you may have to hold the power button in for several seconds....does your ps3 work on a non hidef tv?
Testimonial: "Thanks, restoring the original settings worked. A picture will only display up to a resolution of 1080i, not 1080p."
1helpful
2answers
My ps3 won't play DVDs in Brazil it says the DVD zone is not suported?
DVDs have reigon codes. A PS3 sold in the US will only play DVDs and Blu-Rays that have a region code of 1. DVDs sold in Brazil have the region code of 4, so they will not work.
3answers
My ps3 will play ps3 games but not dvds. it loads the dvd then turns black. Any suggestions?
You can follow below steps to play DVDs on PS3.
Step 1: Insert Blu-ray disc into PS3's Blu-ray drive. Playing Blu-ray disc movie works exactly the same way as entering a game, except you need to head into the Video Tab in your PS3's home menu, rather than the Game Tab. Highlight the Blu-Ray and press X to start it immediately.
Step 2: Now the Blu-ray disc will load like a traditional DVD. Use your controller to access the menu, and use the D-Pad to select your option and press X to enter. When the media is playing, you can press triangle to open a mini-menu that will give you access to options such as subtitles, audio channels and volume. You can also access the main menu, using the arrow keys to navigate. Press triangle again to close this menu.
However, if you can't do it successfully, try to convert DVD to regular video and transfer to PS3.
Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it.
Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting.
Step 3: Load Blu-ray sources
Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading.
Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc.
Step 4: Do output settings
Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony".
Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc.
Step 5: Start converting Blu-ray to PS3
Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos.
Note: Internet connection is required during the whole conversion.
After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part.
For more details, check: Direct and Indirect Ways to Play Blu-Ray on PS3
1helpful
2answers
PS3 will play blu-rays just fine, but not DVD
A bad laser could affect the sound cause it can't read all the information from the disc. Try games as well and see if it does the same thing, sounds like a new drive is in order. There is one laser in those drives and require different strengths to read different discs. Also try a music disc that you know is good. If your still getting the same issue then get the drive replaced or just replace the laser if you have some technical knowledge.
4answers
PS3 will play games but not movies
Well if the regular dvd's dont work.. I would recommend you to buy Blu-Ray movies instead.. PS3 is the best known blu-ray player. buy at least one blu-ray movie and try that.
2helpful
3answers
Baught my PS3 in the sates dont wanna play south african dvds and games
Please go through the booklet provided with your PS3. It will show you what type of DVDs it can play. Make sure that the South African DVDs you are playing are compatible with the one listed in the booklet. Best is to play Blue ray DVD which are slightly expansive but are regional code free. They can be played on PS3 without any hitch.
3answers
Replaced blu-ray laser on ps3 games play but not dvds
thats becouse it a BLU-RAY it is diffrent i figured out the hrd way 2 :P
2answers
American DVDs unable to play for my PS3
At this time the region lock on ps3 only includes DVD and ps1-2 titles. Although some games will have the 80028F10 error. Most ps3 and blue ray will play without problems, my only suggestion being that if you are in the US, make sure you get a US ps3.
hope this helps.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
