Radio just quit playing ... was fine Friday on the way home. Got in car Monday morning and nothing. No info .. checked fuses and they are all fine that I can see .. under hood and in passenger floorboard even checked trunk fuses. Pontiac 2007 G6 2.4 liter
You were right for checking those two first, because they were most likely to be the points of failure. Seeing as you have checked them, i would look to see if the cable coming from your battery is making proper contact and that the wire is intact all the way to the console. This might take some time but it would be the only reason for the lack of power.
did you check the fuse or relay for windows! if need be take out master switch and check for power. if power, then maybe the ground wire is bad. have a good day !!
Monday through Friday look at the LED on the rear of the motor unit. If it is flashing rapidly you have radio interference. See if you can locate the source. It will be something electrical - maybe a military base if nearby.
