Question about Motorola XTN Series Pro Two-Way Radio XV2600 Phone (XTNXV2600)
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
  • Motorola Master
  • 1,655 Answers
Here is a link to the CP100 user manual, it is the sister radioI need to fix the frequency to match my other - 2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
Posted on Nov 08, 2009
SOURCE:
How to program a Motorola rdm2070d to a baofeng bf888s
The RMD has a set frequency list. Those are factory programmed and cannot be changed. Your baofeng can be reprogrammed to most frequencies.
Critical! First, make certain both are in the same band: Uhf or Vhf.
Make the list of frequencies you need both radios to use. If the RDM has it in the list, you are good to go! If it does not, and you must match the Bao, get a new radio. There are no mods or hacks for an RDM.
Feb 25, 2017 | Motorola Radio Communications
What motorola radios are compatible with mu21cv, mu22cv and mu24cv
Any Uhf Motorola business radio can be programmed to match. None of the toy radios will ever work. (GMRS/FRS)
Easiest to self program will be the the XTN, also called CP100, and RD (RDU) and even older Spirit and SP10 are possible, but harder. RD's are really hard without the programming cable, available from a dealer.
Sep 08, 2015 | Motorola Radio Communications
Frecuencias radio xtn xu2601
The frequencies programmed into the radio vary by the Country the radio was to be sold in. For instance, the frequencies for the XTN for the USA is different than the frequencies available for Canada. What is your question? How to program or what are the frequencies?
Mar 03, 2014 | Motorola XTN UHF Two-Way Radio Series
UNLCOCK MOTOROLA XTN SERIES
Here's a link to the manual where you will find programming info https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwi41fis6eLJAhUF5CYKHTgFAFQQFggdMAA&url=https%3A%2F%2Fwww.buytwowayradios.com%2FProducts%2FMotorola%2Fmanuals%2FXTN-series-manual.pdf&usg=AFQjCNFIOd86CBLE45ZNgdfTwEtH6ZhRsA&cad=rja
Oct 08, 2013 | Motorola XV2600 (6 Channels) 2-Way Radio
How to set channels to be thesame on all motorola xtn series radios
Here is a link to the user guide for the XTN style radio. http://www.123radios.com/manuals/xtnmanual.pdf
Programming instructions begin on page 18. You will need to set the frequency and interference eliminator code (PL code) the same on all the radios.
When you enter programming mode, you can use the menu button to walk you through the various options you can program.
Best regards.
Nov 21, 2012 | Motorola XTN 2-Way Radio
Xtn series won't transmit through remote microphone
Here are a handful of problems you might be having:
1) Be certain the radio is turned OFF when plugging in an audio device.
2) Be certain the remote mic is plugged all the way in, until you feel a slight click.
3) Your accessory jack could be wobbled or worn from plugging and unplugging chargers/audio devices. If so, the radio would need repair.
4) Your remote mic is not working. Try it on another unit to confirm.
5) Or the remote mic is not the one designed to go with the XTN radio.
Best regards.
Jun 18, 2012 | Motorola XV2600 XTN Series Portable...
I HAVE A OLD XV1100 THAT I WANT TO PROGRAM TO MY RDV2020 RADIO IS IT POSSIBLE.
Yes. First you will need to know what is programmed in your newer RDV2020, both the frequency and PL code. Using the instructions in the XTN series user guide you can reprogram your XV1100 to match your RDV2020. If you are uncertain how your RDV2020 is programmed, contact your local Motorola dealer or the vendor who you purchased the unit from.
Here is the link to the XTN series user guide. See programming instructions beginning on page 18.
Best regards.
Dec 23, 2011 | Motorola XV1100 (1 Channel) 2-Way Radio
My XU2100 XTN series 2 Way radio is not working. Not receiving or sending transmissions to the other two radios. It is fully charged. It does not make an audible "beep" when you turn it on. ...
Your radio is likely in need of repair. Flat rate repair for this model usually runs around $69. The fact it does not give you the initialization beep indicates it is more than a frequency problem. Then coupled with you do not have transmit or receive, this sounds like you have more of a problem than a bad speaker.
A few things to check before sending it for repair would be:
1) Swap the battery with a known good unit to see if your battery is bad/low and doesn't have enough power to function the radio fully.
2) Check your frequency and code to see if it matches your other units. This is in the upper right corner of the screen shortly after turning the radio on.
3) Check your mic opening in the grill of the radio to be certain it is not covered or free from debris.
If these any of these three items do not solve the problem, you should send your radio for repair.
Best regards.
Nov 12, 2010 | Motorola XTN UHF Two-Way Radio Series
I work where we need two way radios i purchased used ones from ebay and took them to work and set them to the codes that the directions said. both the motorola xtn series and the cp100..older models. they...
On the XTN and CP100 series radios you have 4-6 items which would need to be programmed: Frequency, Code, Scramble, Wideband/Narrowband, Mic Gain, and VOX. You can tell when you've reached the end of programming through the steps because the "chirp" will sound different.
Just a few thoughts which might help you:
1) Check to see these items match identically: frequency, code, scramble and wide/narrowband. (note: the numbering system on frequencies differs between the two models.)
2) If you are using an audio device and/or VOX, be sure you have the radio turned OFF when plugging in the device.
3) Check your mic hole to make certain you do not have debris or something covering the hole.
Educated guess you might have the code set differently between the radios. If these suggestions do not solve the problem, google our company name and give us a call, we can walk you through checking the programming over the phone. Have both a known good CP100 and XTN radio handy.
Best regards.
Sep 30, 2010 | Motorola Walkie Talkie 2-Way Radio
No user manual for the RDV2080d
Here is a link to the programming software http://www.radioserviceincorporated.com/files/1935423/uploaded/RDX_Series_CPS_R01-00.zip
And here is a link to the user guide http://www.astracomm.com/media/pdf/RDX_Display.pdf
The RDV2080 VHF with display would be compatible with the XTN series radios which have a model name starting with XV, as in VHF. Typically the RDV2080 ships on the default frequencies found in the XV2600. So if you have not changed your XTN frequencies/PL code they may match out of the box.
On a sidenote: The Motorola CP110 VHF is also compatible. It is an industrial version of the RDX radio. It has a few more channel capability and a replaceable antenna. It looks just like the RDX models, and it is the replacement radio for the CP100 and/or XTN.
All of the above mentioned models are repairable.
Jul 20, 2009 | Motorola RDV2080d Two Way Radio
Lands Phones Logo
726 people viewed this question
Top Motorola Lands Phones Experts
Marvin
Marvin
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
