SOURCE: Fuji Finepix S5000 ccd sensor
hi dude, i'm eric regarding your ccd problem , first i need to know where you buy this camera. if in singapore so you are lucky, because all s5000 model if that conform is ccd problem that is FOC for repair, but perhap other country olso is FOC for replace the ccd .maybe you log on to www.fujifilm.com.sg for more detail.my s5000 just replace the ccd and foc.ok good luck
regards
ericquah/2/7/08
SOURCE: Fuji FinePix S5000 stopped taking pictures. Told need sensor?//
CCD failed, replacement needed.
SOURCE: I have been given a camera Fuji FinePix S5000 without instruction
here is the link for download
It is a PDF file and you can print it.
Good luck
http://www.fuji.fi/documents/12/5000_manual.pdf
SOURCE: I have a Fuji FinePix S5000 and the battery door
I had this problem also (see below).
After
getting poor results with the duct tape solution, I discovered another
work-around. This should work whether it is chipped lugs on the door or
on the body.
Firstly I used an old camera flash bracket that
screws into the tripod socket, and this holds the battery door in place
quite securely. However it was too long, so I cut and filed a piece of
aluminium 25mm (1") wide by 2.5mm thick to the right length (around
100mm/4") and shape, and made a hole for the bracket screw.
End result is not exactly like new, but more functional than the duct tape and does not further damage the actual camera:
SOURCE: Broken cover on a Fuji FinePix S5000
I think it will stay closed with painters tape or gaffer tape. this type of tape is blue or black. it is strong but not super sticky. I also have the same camera. my battery cover broke after the strap got stuck on a door handle to my office and the door kinda crunched it.
