Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking water from the front of machine, - Whirlpool Duet GHW9150P Front Load Washer
Radio Code Pro
Level 3:
  • Master 2,200 Answers
  • Posted on Nov 03, 2009
Radio Code Pro
Master
Level 3:
Answers
2200
Questions
0
Helped
642941
Points
6531
Hi
The water level in a front loader should always be below the door line so consequently it should not be possible for water to leak out the door unless there is a problem with the actual door seal itself.
However if you are using too much, or incorrect type of detergent, the washer may be producing too much suds. Too much suds can cause door to leak.
Other causes of a leak which appears to be coming from the front but is on fact coming from elsewhere: Check the water inlet hoses. Check the drain hose. Check the standpipe (upright drain pipe used instead of a sink), or the wash sink connections. These will often be the actual source of a leak. When they leak the water can roll under the washing machine and appear at the front.
Also check this link for a good description of how to troubleshoot leaks happening at various stages during the cycle.
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itleaks
Hope this helps. Thanks for using FixYa.
suelack1
Level 2:
New Friend:
  • Expert 42 Answers
suelack1
Expert
Level 2:
New Friend:
Answers
42
Questions
0
Helped
6860
Points
115
If it leaks from the drawer take it out clean it all out inside,if it`s from the bottom look for a leak in the pipe`s i had a needle through one of my pipe`s,if it is from the door,then your door seal has gone
Electrolux EWT 604S Front Load Washer. It started intermittently leaking water under machine itself even when not in use. Anyone had the same problem? How did you resolve it?
Why Is My Electrolux Front Load Washer Leaking Water?
Advance Appliance Service https://advanceappliance.com > blog > electrolux-front...
Oct 1, 2020 - A washing machine leaking from the front door usually means the door's gasket isn't functioning properly. When the door is closed, the gasket ...
Missing: ewt ‎ 604s
Washing machine is leaking water
Electrolux UK https://www.electrolux.co.uk > support > laundry > wa...
Jul 15, 2022 - Check if the leak is coming from the tap itself. Check the water supply connection to the inlet hose of the machine.
Missing: ewt ‎ 604s
Electrolux Front Load Washer Leaking Water? ' D & T ...
D&T Appliance Service https://www.dtappliance.com > blog > electrolux-front...
Aug 1, 2021 - If you find your washer leaking from the back it usually indicates an issue with the drain or water inlet hoses. Connection points are common ...
Missing: ewt ‎ 604s
Electrolux Washing Machine - Washer Leaking Water
Repair Clinic https://www.repairclinic.com > RepairHelp > Electrolu...
Here are the most common reasons your Electrolux washing machine is leaking water - and the parts & instructions to fix the problem yourself.
Slip a sheet of newspaper under the bottom of the machine and it will indicate the area. If is does it when the machine is not running. My guess is that it is around the pump because some water always sits there, so either the pump body or the drain hose itself.
1helpful
Water leak from front loading machine
at a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
5helpful
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
4helpful
2answers
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
1helpful
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
2answers
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
