We have had our Polycom SoundStation EX since Oct09 and it has worked so well for us. Last week it stopped conferencing an additional call. We powered the entire phone system with no improvement. Any ideas?
The SoundStation Premier and Soundstation Premier EX has been discontinued and is no longer available for purchase. Support for the product will be available until 02/21/2010.
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station. On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button. Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider. If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX.
Hope that helps.
Someone in our office recently damaged the RJ-45 cable for our
Polycom Soundstation. Because the jack was damaged I could not
determine the order of the cables. After a call to polycom, we found
the pinout information we needed - so I thought I would share, in case
anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
Black
Brown
Red
Orange
Yellow
Green
Blue
White
Then Crimp and test. I got this information directly from Polycom
for use with the Polycom Soundstation. This information was not easy to
get. They originally told me they could not provide the information and
I would have to buy a power adapter. This is not true, just trim the
cable and follow the above instructions.
