SMALL BLACK CRAYON-LIKE PARTICLES ARE APPEARING IN THE WASHER BASKET AFTER WASHING CLOTHING. THIS HAS BEEN OCCURING FOR THE PAST FEW WEEKS. COULD A GASKET OR BELT BE DISINTEGRATING AND CAUSING THE DEPOSITS?
After technician put a chemical in it to wash away calcium deposits the lower dishrack has been disintegrating. Where do I purchase another dishrack?After technician put a chemical in it to wash away calcium deposits the lower dishrack has been disintegrating. Where do I purchase another dishrack?
You can't post conmments that contain an email address.
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Be sure to seperate lint givers with lint taker, do not mix towels etc with clothes that are attracted to lint. Also be sure water levels are sufficient
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
THE DRUM INCLINE BOTH PLASTIC AND MEATAL SCRATCHING FROM DRUM CAUSE LIKE A CRAYON /SMALL PARTICLES , THE SUPPORT SPRING BESIDE THE DRUM ARE DETACHED NEED TO INSTALL SPRING / AVAILABLE IN APPLIANCES CENTER.
