My phone (motorola SlvrL6i) is requesting the passkey that was initially set inorder to bond my motorola H700c bluetooth headset. Unfortunately for me I dont recall it. I haven't had to use that passkey for months since I first got the headset along with my last phone, but now that I've switched phones and do require it I dont remember it. What can I do?
i got a bluetooth but havin gproblem with connecting to my friend new mobile.what should i doi got a bluetooth but havin gproblem with connecting to my friend new mobile.what should i do
forgott the code and i got a new phone which is a motorola boost mobil please can i get the code to ajust it forgott the code and i got a new phone which is a motorola boost mobil please can i get the code to ajust it
AnonymousNov 01, 2008
linking bluetooh and in need of passkey
AnonymousNov 08, 2008
i cant remember my passcode i cant remember my passcode
i tried entering "0000" & "1234" as the pin and it still didn't work. Does anyone know any other pins??i tried entering "0000" & "1234" as the pin and it still didn't work. Does anyone know any other pins??
You can't post conmments that contain an email address.
1.Switch on the bluetooth on your phone.
2.Open the headset boom to initiate easy pairing. After a few moments, the indicator light will be steadily lit in purple to indicate
headset is in pairing mode..Motorola H700 will be detected.
3.Go to handsfree and select 'look for devices'.
4.Select Motorola H700.Select Yes to bond. Enter the passkey 0000 and select OK.
Thank You
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headsetand press and hold the big button. It should then turn purple and should be recognized.
Also make sure the batteryon theheadset is charged before doing this.
hi have motorola h700 bluetooth device but i forget my passcode how do i reset it again i tried many passcode like 0000, 1234, 1111 ,2222, 3333,4444,5555,6666,7777,8888,9999, but its not connecting wat do i do nw.. plz solve my problem.... my email address is [email protected]
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select H700 once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
Tips: 1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset. 2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On". 3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works. Thanks for using FixYa.
i forgot the passkey what do i do to reset it
