My phone (motorola SlvrL6i) is requesting the passkey that was initially set inorder to bond my motorola H700c bluetooth headset. Unfortunately for me I dont recall it. I haven't had to use that passkey for months since I first got the headset along with my last phone, but now that I've switched phones and do require it I dont remember it. What can I do?
I HAVE A NEW PHONE sch-R400 SAMSUNG AND I DEED THE PASSKEY TO ACTIVATE MY BLUETOOTHI HAVE A NEW PHONE sch-R400 SAMSUNG AND I DEED THE PASSKEY TO ACTIVATE MY BLUETOOTH
forgot password to connect bluetooth with phone. Is there any way to reset password? forgot password to connect bluetooth with phone. Is there any way to reset password?
I have the same problem I don't remember the code to link the hetset with my phone.I have the same problem I don't remember the code to link the hetset with my phone.
Yes! I don't know the passkey to bond the bluetooth with my phone. I need a passkey.Yes! I don't know the passkey to bond the bluetooth with my phone. I need a passkey.
AnonymousJun 30, 2008
I DONT HAVE THE PASSKEY TO LINK MY BLUETOOTH TO MY PHONEI DONT HAVE THE PASSKEY TO LINK MY BLUETOOTH TO MY PHONE
1.Switch on the bluetooth on your phone.
2.Open the headset boom to initiate easy pairing. After a few moments, the indicator light will be steadily lit in purple to indicate
headset is in pairing mode..Motorola H700 will be detected.
3.Go to handsfree and select 'look for devices'.
4.Select Motorola H700.Select Yes to bond. Enter the passkey 0000 and select OK.
Thank You
Read the manual its in there the factory setting for most is 0000 if you reset it and forgot it try disabling bluetooth on your phone the enable it ...be sure to remove the bluetooth from the recognized list too
switch on the bluetooth on both the devices..and then search for the device in your phone.if it is visible you have to enter a passkey initially and then you will be able to connect it. this is one way, and put on the music player in the phone, switch the option in the settings to hear through wireless bluetooth.if it does not work, then try the bluetooth with a motorola phone.if it works with the motorola phone alone then it might have compatibility problems with nokia. generally motorazr is best suited for the bluetooth u have
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
a) Options->Bluetooth->Enable Bluetooth
b) switched on the Moto headset (blue light blinking)
c) options->bluetooth->add device
d) searching for devices....---> here it should find the headset and pair....
If it does not work do the following
After doing the above, do the following:
e). Start the headset. Start with the headset powered off, and hold
the Call button for 10 seconds or so, until the light stays on.
(Initially, the light will flash a few times before getting steady.) If
the light is flashing, or if the light starts flashing anytime during
steps f) through g), the headset is not in pairing mode, and this step
(step e) must be repeated, again starting with headset powered off.
Select the Headset:
f.) Go back to phone, and select "[Look for Devices]." The phone starts searching for Bluetooth devices.
g). Once phone is finished searching, you get a list of one or more devices
under the heading "Scan Results." Select the headset.
h). The next screen will read "Bond With ..headset." Select "Yes."
i). The next screen will be "Enter Bluetooth Passkey." Enter
0000 and select "OK." A screen will confirm pairing and connection. When the pairing is complete, the light on the headset
will flash.
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select H700 once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
Tips: 1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset. 2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On". 3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works. Thanks for using FixYa.
dont remember pass code
I do not recall the code
need manual for h700
I need pairing instructions
siver
