Samsung FPT5084 50 in. Plasma HDTV Logo
Anonymous Posted on Nov 03, 2009
Samsung FP-T5084 No picture
My neighbor gave me a Samsung FP-T5084 50'' Plasma TV that no longer works. He had a sevice tech check the power supply and replace the keyboard, but it still does not show a picture. Power lights indicate TV is getting power. Service tech said Y-board, Is this something that can be easily replaced myself? Is it worth the cost? The TV is 1 yr old.
  • Anonymous Nov 04, 2009
    would you recommend trying the y - board replacement myself? and how do I know which one it is?
Anonymous
Level 3:
  • Master 335 Answers
  • Posted on Nov 03, 2009
Anonymous
Master
Level 3:
Answers
335
Questions
0
Helped
128248
Points
1005
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Testimonial: "Thank you. your feedback was appreciated. Theres a lot of value in getting an expert opinion whether to fix or not to fix."
yrk27t
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 08, 2009
yrk27t
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
9996
Points
9
If you can't get it to work I would be interesting in buying it since my screen got cracked on mine (don't ask LOL)
Feel free to email me at yrk2.7t AT (replace with @ symbol) gmail.com
Thanks!
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Samsung fp-t5084 fuse fix is the replacement fuse slow burn or fast burn?
I'm certain it uses a T12amp slow blow type. I have the exact same model, you can replace the fuse. The TV will for a while, but that fuse will blow again. You will need to replace the power supply board for a more permanent fix.
2answers
1helpful
Fp-t5084 Samsung 50" Plasma does
Hi, Here are some basic steps that will help you fixing the problem. I'm assuming that your unit is dead set without an standby LEDlight and your outlet is live.1.Power cord - check the cord it might be opened (nocontinuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse-sometimes the fuse fail because of the powersurge, replacing with new one will cure the problem, If this is the case Iwould advice you to use surge protector/AVR (Automatic Voltage Regulator).However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit thelinkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction andstill the unit didn't power up then you have an open parts on the power supply. 4.If you see that the fuse is intact , don't attempt to touch anythingbecause there some fatalcomponentsstored electricity enough to hurt you with a simple mistake only. I wouldadvice you to look for aprofessional to troubleshootthe power supply. If you want to repair it yourself make sure that you havenecessary tools and testinstrument. First check bad solder joints(re-solder allcold solder), leakyelectrolytic capacitor(sometimes it has bulged at the top but not all, you betterhave a capacitor checker), open/shorted regulator transistor/IC(mounted in heatsink), open fusible resistor (caused by shorted regulatorTransistor/IC), shorted zenerdiode. You may also replace the power supply board, this is more convenient if you are going to DIY because no soldering required. Obtain the board from your local Samsung service centers.
Also check if your unit is under warranty before opening the backpanel, it will void the warranty. Avail it because the manufacturer of yourunit will fix it for free or a little charge only. Hope I helped you. Have a nice day! Thanks for using fixya.
My samsun fp-t5084 is making a loud whining noise
its either a fan going out or power transformer. take the panel off and turn on the unit while being careful not to touch anything at all while power is to the device. plug it in and listen so you can identify the component. If its a transformer (it would more than likely be square and wrapped in a thick polymer sheeting.) it will be fine, possible for good. If its the fan making noise, you will typically have 9-12mths from the time you first here the sound before the perfomance is affected.
SO, to make a long story short, a hummming sound is typically the sound of electrical variations in a component, whining is normally a rubbing action within metal and plastic components.
(plastic on plastic makes a squeek, metal on metal a higher pitched squeek)
1helpful
My Samsung FPT5084 50 Inch Plasma TV....keeps turning itself on and off. Does a solution exist to my problem. I am out of warranty,
http://www.retrevo.com/support/Samsung-FP-T5084-TVs-manual/id/2839bh444/t/2/
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010200&prd_mdl_cd=&prd_mdl_name=FP-T5084
Below is the service manual link from epox. ftp://ftp.epox.com/downloads/Manual/mu-8KDA3J&+11.pdf
This is usually a switchmode power supply problem, and it's shutting down, for safety reasons, so as to avoid a fire and explosion or both. Realistically you need to get a "Quote" from an authorised service agent, for repair.
I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. It was plugged into a power strip with other...
Could be the PCB, but it is hard to say. I am looking for one that has a good screen since mine got cracked (don't ask LOL) so if you are interested in selling it let me know.
Thanks!
Samsung fp t5084 Plasma TV it won't turn on... but its clicking... what is wrong with it?
could be H-OUT TRANISITOR or it needs resoldering in the whole board. this component provides picture in tv. if no pwer is in your system, check out for power regulator, capacitors, fusable resistors any power area. if you are familar with electronic repairs, or give to qualified service personal
34helpful
4answers
No power to Samsung FP-T5084
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
