Kenmore 24032\24036 Top Load Washer Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The water was dripping into the bucket after the final rinse and leaving clothes soaked. I have replaced both hoses (they were old anyway) and it continues to do it. It stops when I turn the cold water off.
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Nov 03, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367321
Points
3700
It sounds like you have a bad water valve
it can be very easily replaced
goto www.appliancepartspros.com
type in your model number
this link will show you both the part and how to get to it
2answers
Only hot water filling washer on all settings
have you replaced the hoses? it's a good idea to do that every few years anyway (they get old and often burst) ... some hoses have an inline screen filter that can get stopped up thus your washer would only get hot water if the cold water hose was stopped up.
IS THERE ANY PROBLEM IF POUR WATER INTO THE MACHINE WITH A BUCKET WITHOUT CONNECTING TAP WATER SUPPLY HOSE
One problem you might encounter is not having enough water for your cycle or having too much, plus there are times during the rinse cycle that it sprays the water in a little at a time to help loosen the soap and dirt from the clothes. I would recommend leaving it connected to your water supply.
Washing machine leaking
It sounds like the water valves are not shutting off completely.
You have faulty water valves & need to replace the leaking one.
1helpful
No problem just want to know if one can put clothes soaking in bucket into the machine and go straight to spin to get excess water out without going thru the whole washing process. Cheerz!
Hi - yes theres a few options start it on the final rinse and set your water level to low or auto sense then spin speed (this will add more water to stabilesde the spin cycle)
Could go direct to spin as well but you will need to adjust the clothing proper prior to starting of the cycle..
How to clean adidas vespa shoes
The accompanying low cut Vespa GS is a perfect example of how a clean and simple sneaker can transcend the sum of its parts.
the adidas vespa is a sporty shoe ,it should be cleaned with care so that it colour dont shade off
follow these simple steps
1) take a bucket of warm water
2) dip solution of soap in the bucket of water
3) dip the shoes in the warm water and leave it for some time ,let it get soaked.
finally take the shoes out and clean it with dry cloth and leave it dry for some time
if my advice is use ful for you please vote 3 thumps to my solution
2helpful
Washer will not do Final spin. the time stays on one minent for about 8 mins with no final spin
If the clothes are extracted of water it very well mean your timer needs adjusted slightly, If not, timer needs replaced. Remember, not 100% of your rinse water will be extracted so don't expect it to be hand touch dry when you remove load.But it should not be dripping wet or soaked either
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
1helpful
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Maytag mah4000aww motor control board bad cannot tell which series it is serial 53312313yk
my front load washer is leaving water after done spin cycle can still ring water out of clothing....water is draining from hose and is spinning somewhat strange...like its not going through rinse properly sorta like its repeatedly doing same cycle pattern...spins for lil, stops makes running noses...spins sum more....soapy clothing...its 5 years old..but first time use this month finally connected it...when took bottom off to check hose connection noticed control board looked lil warped and brownish colored but not as meant to be..maybe its burnt out?
Alexander
vince
