Sony VAIO GRV670 Notebook Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Vaio buzzing fan noise
My Sony Vaio VGN-CS320J, which I bought 4 months ago, is making an intermittent buzzing sound. The buzzing seems to accompany the fan when it comes on. The fan has always been loud, but it has never buzzed until recently. It used to only make a clear airy noise, but the sound has changed drastically to an unpredictable buzz. Nothing noticeable has happened to trigger the problem.
Anonymous
Level 2:
  • Expert 192 Answers
  • Posted on Aug 05, 2010
Anonymous
Expert
Level 2:
Answers
192
Questions
0
Helped
103538
Points
403
My sony vgn =cs320j would not shut down and we did manually because if=t was feeaxzing.Then when we started it mentioned ntfs and did startup repaiir .after 6 hours in startup repair it did nothiung.so we...
What version or Windows are you running? Try booting with your Windows disc and select repair. Get to a DOS prompt and overwrite the file with the same name file from the CD. The file may also be located in whatever drive letter the system assigns your repair CD. (Usually X I think).
My sony vaio laptop VGN-CS320J shuts off sometimes for no reason. Sometimes the fan alos makes noise. There is no virus and i have checked throughly. It runs on Windows 7 home premium. Can u help me
From the details that you give it seems that the problem is the fan, it does not work well.
What you can do is to check if there is some dust accumulation by watching from the holes where the hot air should come out (usually on the sides of the laptop).
Then you can use a can of compressed air to clean it better and a vacuum cleaner, but not too powerful, to **** up the remaining dust accumulation.
After this, even if it does not work, you'll might contact the Sony support.
Sony VAIO(R) VGN-CS320J/P PC Notebook
Please tells in detail what it the problem
Regards
The fan of my Sony Vaio VGN-CS36GJ laptop has been making a loud buzzing sound for the past 2 and a half months; it almost sounds like a truck. The sound is not constant, but intermittent - it comes up...
You'd better open up the laptop and do a thorough cleanup, and do the cleanup each 3 months. While you're at it, get a lubricant for cleaning up and degreasing electronic contacts and spray a bit of it in the electric motor of the fan. These cans are cheap and you can probably find it in your local supermarket or electronic repair shop.
This buzzing noise may be caused by a dust clog, or a dried out spindle axis. The thorough cleanup and lubrication will help. I've done this countless times on many laptop models. The other option is buying a new fan, which can sometimes cost up to $50, so better do the cleanup. Its free :)
1helpful
My laptop (sony vaio VGN-CS325J) fan makes a horrible noise
Hi kufreudokang,
The VGN-CS1xx, VGN-CS2xx, VGN-CS3xx computer models have a known issue that the cooling fan in the Computer may make continuous scraping, whirring, chriping and/or clicking noise while running. As a part of Sony's commitment to quality, Sony provides a free repair for an additional 36 months beyond the standard limited 12 month warranty (48 months total) for fan replacement.
As you're experiencing the issue, you can contact Sony Support at 1-888-476-6972 to set up a repair service at our Sony repair facility.
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
How can i fix the noise on my sony vaio vgn-cs11z.....it goes off every seconds
the noise might be coming from the fan.. call sony and check if your unit is eligible for fan replacement
2397687669
My vaio vgn-cs320j makes a loud spinning noise that comes and goes every few seconds or minutes. Is it the fan not working properly or some other issue, or is that just what the fan sounds like? if it is...
Usually Sound from Notebook are from CPU cooling fan and from Hard drive.
But It's hardly occur in the case of Hard drive.we called it Hard drive failure and the only solution for this is new replacement.
Your problem could be CPU cooling fan not working properly. Open the Notebook ( it will be easy if you refer to manual on how to open) and start the system now, you will be able to pinpoint what causes the sound.
Clean the CPU cooling fan with an air blower and re-check if the problem still persists.
If OK,then close the Notebook otherwise replace the CPU Cooling fan with a new one.
4helpful
3answers
Sony vaio fan is making a grinding noise, how can i fix this?
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
1helpful
Sony Vaio fan making noise
Hi:
Not sure of a user cause for the fan to run full speed, unless you are using the laptop in a high heat environment, or setting it on a bed or other area where it is not getting adequet cooling air. If it does it right away, when you turn it on , cold, then there might be a laptop hardware problem. If you leave your laptop on all the time, then you might be inducing the problem. I had a HP high performance laptop, that the fans would not turn on at all till it ran an hour or so, then they would stay on loud for 10 or 15 minutes, then shut off, then cycle.
Fan of VAIO CS-118E makes loud sounds
That is definitely a problem from the fan. What you can do is to call sony and check if they still cover Fan replacement for this specific mode.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
