* For text ads, append each ad to the string.
for(i = 0; i ' +
'Ads by Google' +
google_ads[i].line1 + '';
url = '' +
google_ads[i].visible_url + '';
info = makeBoldAdWords(google_ads[i].line2) + ' ' +
makeBoldAdWords(google_ads[i].line3) + ' ';
s += url + info;
s += '';
s += '';
document.write(s);
G_GGL_SKIP += google_ads.length;
return;
var G_MAX_ADS_WL = 1;
google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#)
google_ad_channel = "4447185069+1147946396";
google_ad_output = 'js';
google_max_num_ads = '1';
google_ad_type = 'text';
google_feedback = 'on';
if(typeof G_GGL_SKIP == 'undefined')
G_GGL_SKIP = 0;
google_skip = G_GGL_SKIP;
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Problem with the American Standard Bathtubs / WhirlpoolsBy bassassist69 on Sep 02, 2011 Hello: Please contact us at Wmerican Standard Brands and we will gladly help you. 1-800-442-1902 Monday through Friday 8:00 A.M. to 7:30 P.M. EST
Technical Customer Service Monday through Friday 8:00 A.M. to 6:00 P.M. EST 8:00 A.M. to 3:00 P.M. EST Saturday
The overflow drain / stopper lever has 2 screws holding it in place, place a rag over the drain and remove the 2 screws. then remove the drain assembly, it should slide right out. You can now clean the assembly, you may still need a piece of wire to fish the hair out.
Hard to read you question. No sure what it is but if the flapper is still leaking it may be bcause most brand of fleappers do nto fit American Standard commodes correctly. Purchase a replacement made for American Standard only.
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool) Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
sounds like a circuit board problem. what is the model of pump you have?
