My Mitsubishi ws-65807 has what appears to be a red overlap. Pretty much the same screen twice. Any help on what I should do
SOURCE: MITSUBISHI WS 65807 RED CRT OUT
It' sound like you have a bad crt, to make shure, just disconect the red crt baord and green crt board next to it and move then so you can try the red crt board on the green crt. If it does the same problem in witch I realy thought it's your video or hight voltage sounce on that board. If you get no problem well it's your crt.
I can almost garranty it's your crt.
Bob
SOURCE: Mitsubishi WS-65807 + PS3 1080i Screen goes blank when bright white displayed
Go to PS3 / Display settings. Set superbright OFF, even if you don't have HDMI. Set Cross Color Reduction to OFF. Set Display to only one resolution, not all of them as you probably have it now. Set it ot the highest possible resolution and uncheck all other boxes. The 480i is always on by default. The issue, which was very annoying, was fixed for me. I have a mitsubishi 65 inch RP that is pretty bright on daytime/sunlight scenes, so I never thought it was the PS3, but only whet the PS3 was used did this occur. I scanned this site via google to find that nobody else appeared to have resolved this. So after some changes and testing this solution worked for me. Enjoy! - Dave Walz
P.S. I think the only real fix was to set just one display resolution, but I am now watching a movie and am not going to stop it to find out. :) That's for whomever follows this posting to find out for themselves. Either way, this is working great.
SOURCE: Mitsubishi WS-55819 has double vision screen with
Sounds like bad convergence IC's; this set uses two STK-392-570 IC CHIPS; both should be replaced and the blue 3.9 ohm resistors in front of them should be checked. Get someone who has done this repair on this kind of set before--it is usually not something for a do it yourself person; the middle pc board needs to be removed to safely replace the chips; then the set needs to be adjusted in the regular and HD modes. If this is helpful, give me a vote. if you need more direct information email me: [email protected]
SOURCE: cant find part #stk-392-570 for mitsubishi
SIMPLE---GO TO EBAY--
SELECT SEARCH THEN ADVANCED SEARCH AND THEN SEARCH BY SELLER---
sewsales55 is the one I buy mine from--company in Maryland---called SUBURBAN ELECTRONICS--
THEY HAVE THE CHIPS AND OTHER THINGS--also have a online catalog you can order from--usually their prices on Ebay are a bit lower than the catalog prices....
6 month warranty of the chips
IF this helps you, rate this solution as I do this here for free---they are the lowest price best source for these chips and other parts.
SD TECH
SOURCE: My Mitsubishi HD 1080 Model WS-55809 - the colors
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
