The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Fantastic the instructions did the trick. Like the instructions our machine didnt start flashing but when I took my figure of the star/pause button the display should all bars in each light were working (each light showed an "8") I then turn the dail back to off. All lights went out. Then I selected the wash cycle I wanted and it all worked. Thanks for your advice on the net.
Thanks for your comment . It was worked .
Fantastic. It worked just like yours :))
Thank you. Did not flash but cleared the code
Thank you your solution worked.
After 1 minute code did not flash but was cleared
Thanks for that, worked a treat
Thanks so much worked a treat!
God's holy providence has been working out for us finding this great tip ! Thanks for your message Sanja Salatic !!
You Sir are an absolute legend!
thats so much woohoo
Thanks very helpful.
I only had to hold in the start pause button for 10 secs and not for the minute on a 6.5kg max classic machine. And thanks for this handy reset tip.
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
error e2 comes up and machine stops and beeps
