Your back light inverter power supply has failed. We have a step by step repair guide with parts list posted on our web site at: www.ccl-la.com/badcaps.htm
Check it out.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
rubyreddress, Hi there, Check out my response that I wrote to mccarthympls about his E173FPd black screen problem. You should do a " I HAVE SAME PROBLEM" comment to that also, and do the recommended Flashlight Test and then tell us what you found out. If your monitor was working PERFECTLY the day before, then you might have a shot at having it repaired. Here is what might happen when you show up at the store to trade-in your E173FPd on a new wide-screen unit. The sales guy is going to drop off the E173FPd on the repair tech's bench and then the repair tech will open up your old unit and with a little bit of luck and a soldering iron and $3 to $7 in parts will now have a working monitor that will last another 2-3 years. You too, should visit YOUTUBE and find out whats possibly the problem inside your monitor!! Hope to see your comment. I'm 12fixlouie Bye for now.
