Health & Beauty Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can anyone tell me where i can find a charger for r7130
Can anyone tell me where i can find a charger for my remington r7130 shaver. I have tried everywhere and cant find one to buy.
Anonymous
Level 2:
Guru:
  • Expert 174 Answers
  • Posted on Apr 27, 2012
Anonymous
Expert
Level 2:
Guru:
Answers
174
Questions
0
Helped
106880
Points
179
5 Related Answers
Stan Sexton
  • Posted on Mar 02, 2008
SOURCE: Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Anonymous
  • Posted on Dec 28, 2008
SOURCE: Remington MS2-250 shaver disassembly?
This shaver was pretty clearly not designed for battery replacement. To open, first remove the screen and blades, and unhook the metal collar from the tab on the back of the case. Then carefully pry off the black inset on the front of the shaver. Underneath it, near the bottom are two screws. Remove these. The case is now only held together by several plastic latches, which can be carefully pried apart with a small screwdriver. The two 2/3A size batteries are soldered to the printed circuit board, which can be pulled out (don't break the wires to the motor) by a little wiggling. The original batteries in mine are 1100mAh, and I have just ordered 1600mAh replacements. The new ones don't have tabs - so soldering them in place is probably going to be a challenge.
Good luck.
Anonymous
  • 373 Answers
  • Posted on Feb 06, 2009
SOURCE: Lost charger for philips 7380 shaver
shavers-and-replacement-parts.com
www.PartStore.com
Give these a shot
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Jan 31, 2010
SOURCE: Hello, I have droped my Remington R7130 and
You need a new hed holder. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-head-assembly-without-cutters-for-select-models-p-808.html
Anonymous
  • Posted on Jul 21, 2010
SOURCE: Remington R7130 electic razor cleaning
Just spoke with Remington customer service as I've been having the same problem of once the heads are off, you can't get them to stay back on. They apparently have created a brand new "head" piece that will solve the problem because they had so many complaints. As long as you registered your razor, just call Remington and choose the option for Warranty issues. Tell them your problem and they will mail you the new head which is promised to resolve the issue and make things work easier.
2answers
I have remington rotary shaver R4150 but charger is not working i want to buy a charger
remington r4150 charging power cord
remington PR00009
3.8VDC adapter charging cord for men electric shaver remington r4150 power cord replacement parts.
I am looking for a replacement power cord for remington R7130, where can i get one
remington pa-400 12v adapter power cord for electric shaver remington r7130 charger replacement parts.
Input: 100-240 VAC 50-60 HZ, Output 12VDC 400 MA
remington r7130 charger power cord
2helpful
I have a Remington 360 rotary shaver - model no. R7130. One of the small springs inside one of the rotating cutting heads is missing. Am I able to purchase a spring to fit please?
These springs are not available from Remington for replacement. Your best bet is to go to your local hardware store where they should have a variety of springs available
3helpful
I've lost the hinge for my r7130. where can i buy a new one? Cheers!
Here is there main site, to order parts. Most likely they can help you and send out the right part,
www.remingtonproducts.com Hope this helps, thanks mike from fixya
How often do you have to change the three cutters on my Remington R7130 electric razor
Remington suggests changing the head on model R7130 every 12 months. You will find replacement heads for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
My remington r7130 hair trimmer's battery will not charge.
You can have the battery replaced. This however needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
I lost my charger, can you tell me the energy
12 Vdc 65mA. If you hold the cord the notch is facing to you, the positive side is at your left side. You may check the shaver use a multimeter to ensure the polarity.
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gene Lawson
Mike Cairns
Mike Cairns
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
