HP LaserJet 2840 Printer Logo
Posted on Jan 03, 2008
HP 2840 is printing light even after putting in a new cartridge
On the printer panel it shows how much ink is still left for each color......Well, under setup it shows that it is more than half empty. Is that the drum? How often does the drum need to be replaced? Is that making any sense? Let me know. My email address is: [email protected]
  • changodoug Jan 10, 2008
    the black ink cartridge has been refilled once.
Anonymous
Level 1:
  • Contributor 62 Answers
  • Posted on Jan 10, 2008
Anonymous
Contributor
Level 1:
Answers
62
Questions
0
Helped
22894
Points
77
No, that is not the drum, it has a chip on each toner cartridge that send information back to the printers main computer, and that tells the machine how much is remaining.
Has the cartridges been refilled ? need to know before i move unto the answer.
  • Anonymous Jan 10, 2008
    sorry, did read u had refilled the black cartridge .
    then the toner u r using isnt dark enough.
    try another, that should solve the problem
I have only black toner, colors are out. How can I keep printing? It sends a message: "replace supplies".
You need a supply of ink in both cartridges in order to print. Even if you are only printing black ink and there is a black ink cartridge with ink in it, your printer will not print without the color catridge installed and it has to have a supply of ink in it. I wish I had better news for you, but unfortunately I don't.
My hp 2840 doesnt print in color? it prints in black fine but when it come to color it make the whole page black.
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Our cartridge is new
try taking the cartridge out and cleaning the connection then putting the cartridge back in
Ink light blinking hp920c
Yes, sorry to say. The system uses all carts even to print in black.
Won't print in color
All cartridges are new...report shows 0 pages for yellow left yet all others added at the same time show thousands of pages left. Everything printed is in black with no color. BTW: I have 3,000 pages left with black cartridge and the display says I need black.
What should I do?
2helpful
2answers
Ink cartridge light keeps blinking BEWARE SPAM NUMBER 1-800-532-4187
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
1helpful
Is the color cartridge new and do you know how to check the gauge in your control panel for the ink levels?
1helpful
Hp 2840 "Replace supplies"
If one of the color cartridges runs out the machine will switch to black only mode. However, I have found no way to force it to continue printing in color mode when any one of the cartridges runs out.
k24674
Grand Canyon Tech
Grand Canyon Tech
