Kodak EASYSHARE M1063 Digital Camera Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery won,t charge
Where can i get a new rechargable battery klic7001,and how much do they cost i,ve only had the camera since feb.09
Anonymous
Level 2:
  • Expert 262 Answers
  • Posted on Nov 02, 2009
Anonymous
Expert
Level 2:
Answers
262
Questions
0
Helped
98167
Points
747
The price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at kodak.com/go/shop.,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
Nikon camera battery keeps losing charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
1helpful
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
1helpful
I have charged my batteries for about 4 hrs and inserted into camera but after few minutes it indicates low battery signal
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Please,what batteries do I use for my Nikon CoolpixL22. Thanks for your help
The L22 takes two standard AA batteries. You may use disposable alkalines or lithiums, or rechargeable NiMHs. Don't mix them, that is, use two of the same kind. If you use rechargeables, you must charge them separately; the camera is not a battery charger. You can use any brand, though I'd stick with the major brands.
Lithiums will last longer than alkalines but cost more. Rechargeable batteries cost more and won't hold a charge as long as alkalines, but can be reused.
1helpful
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
HAVE A KODAK 8.1 MODEL M893 CHARGE IT WHEB YOU TURN ON IT'S ON YOU GO TO TAKE PICTURE IT SHUTS OFF
Are you suing the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? If no please purchase KLIC7001
Now in case you are using this KLIC7001, How do you charged the camera or battery? USB cable or AC adaptor? If your using USB cable actually some of the M893 will not charged using USB cable you need to update the firmware or download the firmware before you can successfully charge it using the USB cable
Now if the AC adaptor make sure when you plug the adaptor theres a light indicator on the camera and charged the battery for 4hrs., and still the camera will shuts off everytime you take a picture please call kodak toll free 1 800 235 6325 have your camera repair. Gudluck!
Nov 05, 2009 • Cameras
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
