I receive a "err 01" message in the display when the MCD-6 CD Changer is turned on. Also when eject button is pressed the cartridge does not eject, although a motor sound is heard for approx. 2 sec., during which time a "0.00" is displayed. If while trying to eject, another button is pressed, (Track, Search, etc.,) a "no disc" message is displayed (even though discs are loaded) and returns to "err 01" when the moter sound ceases. Prior to all this, the unit operated properly.
I do not know these units but I have worked on multiplay and many devices, the main reasons I found is either lubrication and or drive belts.
Over time belts stretch from decay as they age also silicon based grease I have found becomes divided between a liquid and paste with the liquid part making a puddle on a units lower area.
This causes things not to operat within a suitable time due to friction or lack of power from those belts which result in error numbers.
A good service is the only answer with a good service engineer who I am sure will enjoy cleaning out the residue slime, clean parts and relubricate. Sarcastic of me maybe but it was to make you aware that it may be costly due to time involved.
Hope this helps.....
SOURCE: disc changer will not eject, system will not play.
http://www.allelectronicsrepair.com/files/MCD6Manual.pdf
There's a phone number on the manual - 1-800-SMART HOME 949-221-9200
I have the same problem as stated above. Help please!
I have display showing ( LIST ) on and off
