Help setting up a rc airplane i have 4 servoes an engine i have a reciever comming with a radio controler how does it all go together and what batteries d i need.
EITHER YOUR ELEVATOR CONTROL CABLE IS BENT OR MISSING, OR THE ELEVATOR ACTUATOR SERVO IS NOT FUNCTIONING NOTE:**** CHECK ALL OPERATIONS BEFORE TAKING TO THE AIR AGAIN...IT GETS COSTLY!!!
Don't worry - with practice you will get used to using your radio controlled airplane. you just have to be patient. take a look at this link for a site that gives instructions for using a remote controlled plane; http://www.stormthecastle.com/model-airplanes/basics-of-controls-of-an-rc-airplane.htm
The <a href="http://lightake.com/products.do/category.Wholesale_RC_Aeroplanes_Aircrafts-424">RC Airplanes</a> task process views for really wonderful. It through many useful information gather from here! I have like this site.
You need a covering iron. They are used to put the covering on the plane. Lower heat to activate the glue to stick it to the wood around the edges and then higher heat to shrink the covering before pressing it down in the middle.
REMOVE CONTROL HORNS AND SET SERVOS TO CENTER POSITION WITH RADIO AND RECONECT HORNS TO SERVOS ,COULD HAVE SLIPPED ON SERVO SPLINES DUE TO A HARD LANDING.
have a look on rcuniverse website for your aeroplane, there is probably a build thread on there, a 110 fourdtroke will be fine, use the best servos you can afford, i like to use hitec 645 servos, 9kg pull, suitable up to 70inch wingspan models
have you got any expo dialled into the settings, this will delay or rather soften the response to your servos, the glitching you are getting may be due to you be close to the reciever and swamping the sinal hence the glitching, see if it goes when you walk away from the transmitter
