hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Make sure the headset is off and there are no flashing lights. On ps3 go to settings and look around cuz i cant remeber were it is at but look for manage devises or manage blue tooth devices something like that. You will select that and it will ask you if you want to search for devices. WAIT! First you need to put your headset in pairing mode. Hold down the side button (the one that flashes blue when it is on) and you will see it turn on and flash. DO NOT LET GO OF THE BUTTON!! KEEP IT HELD DOWN UNTIL THE LIGHT STAYS BLUE, NO FLASHING. you are now in pairing mode! Select search for bluetooth devices on your ps3 and it will begin scanning. keep your headset close to your ps3. When your ps3 finds it, it will ask for a code. Enter 0000. Thats it! ENJOY!
First make sure your bluetooth and your phone are fully charged. Next press the on - off button in the middle of your bluetooth until it is a solid blue color. If it is flashing it is not in the pair mode. Just hold it down until it is a solid blue light.
Then set your phone to the pairing mode following your phones set up bluetooth instructions. Select the discover, search, or add function on your phone. Your phone should find the bluetooth device and ask "do you want to pair with it?" Accept by pressing yes or ok on the phone and entering the passkey or pin # of 0000 or 4 zeros.
Your phone should confirm when pairing is complete.
I discovered that I was not holding the on-off button down long enough for my bluetooth to reach the pairing mode and give me a solid blue light.
I hope this helps as I know how frustrating this can be.
Before the search you need to hold down the power button on the headset.Keep it held down until it stops flashing,the PS3 should be able to read it.My problem is that I lost my instruction manual and don't know the pass key.Can anyone help me there?
Go to PS3. Accessories Setting -> Manage Bluetooth Devices -> Register New Device**
** = You need to have Jabra BT125 in Pairing Mode. Hold the button for more than 10 seconds till it's a solid blue (initially turned off). Then detect it with your PS3.
I was reading in another problem how this guy lost his manuel, and used the internet manuel to get it into paring mode. You are to Hold down the call button untill it turns blue, try that and let me know what happens. Here is the site for the manuel.
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
