Vacuums Logo
Anonymous Posted on Nov 02, 2009
How to replace the power cord for the kenmore vacuum 11620512003
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 04, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
322
Points
I figured out myself,,,,,,,,,the return spring was the BIGGEST challenge,,,whew.....overcame that obstacle with a pair of vice grip plyers.........
HOW TO REPAIR THE RECOIL POWER CORD ON A KENMORE MOD 116.23613300 VACUUM
generally you need to replace the spring mechanism. contact the manufacture for parts/cost. Most local shops don't carry parts to repair vacuums, unless it's a new model, most vacuums are designed to work until they don't then you replace. unless you spend more than 400-500 bucks on it that is.
1helpful
I NEEDED TO FIND OUT HOW TO INSTALL A POWER CORD ON A KENMORE CANNISTER VACUUM (WHISPERTONE) NOT A KITCHEN STOVE.
Hi emery1950,
I have provided you instruction on how to remove the motor canopy to get to the reel cord area and how to replace the reel cord. Kindly click on this link.
Hope it helps.
Thank you for using Fixya.
Cord rewind nonoperational
sounds like the spring is either over stretched or broken. you may have to have the spring replaced
2helpful
Power cord reel problem with a kenmore canister vacuum whisperti
Pull the cord all the way out and see if it's contaminated with anything sticky. Also check the guide rollers that the cord rides in and see if they are rolling smoothly and without resistance - they may also need cleaning. If so, clean it off and try again.
If not, it may be the spring reel itself in which case you may need to replace it.
4helpful
Open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Need to replace power cord
Here are the Sears links to purchase both the part and the manual.
http://www.searspartsdirect.com/partsdirect/searchByPartDescAction!searchByPartDescription.pd?brandId=0582&productCategoryId=0645000&modelNumber=11633922300&backToLink=Return+to+Sub+Components+list&partDescriptio
Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
4helpful
5answers
Kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Jul 16, 2008 • Vacuums
4helpful
2answers
Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Top Kenmore Vacuums Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
