All I can say to you is look around where the mains goes in very carefully. Fuses are sometimes hidden or in a case or cover of some kind. Sometimes amps use fuseable resistors. If the PC board is marked up look for resistors with "RF" or different indication to a normal resistor. Otherwise fuses will have "f" markings on the board. Remember the power supply part might be enclosed in a metal case with holes in it, so might be hard to spot fuses.
I looked inside it and couldn't see anything. I don't know where to check the fuse - read the manual, but it didn't mention it.
How can I see/change the fuses? Checked out rotel's sites and the manual of other rotel-amplifiers, and there it was written that if you believe that the fuses are blown, you have to take it to a rotel authorized repairman, which I will not.
Have you checked inside it for an internal fuse failure or damage?
