I have a Denon AV Receiver Model AVR3600 locked at ''Protection'' Mode after powered 230Vac line. I have removed all the connections including speakers. However, the receiver still remains at '' Protection '' Mode. What should I do ? Thanks & Regards ****
The problem with this receiver is NOT the power supply, but the output stage of the amplifier section. The most common failure is shorted output transistors. There are problem detection circuits that will shutdown the receiver and display the "protect" message when a problem is detected. This is to prevent further damage to the receiver and speakers. The typical parts cost for this repair uis between $20- $40.
Dan
Testimonial: "Thanks for your useful information."
The power supply is damaged and needs to be serviced. You have done exactly what you should have to test for an outside issue, it's the receiver.
