Just sold my sansui mr 6 and new owner says head is stuck in record position so cant load tape, can anyone help
Most likely one of the belts has slipped a bit and the unit is stuck in the middle of a transition. Normally, a power up will "reset" the mechanism. Try that first. The owner should hear the motor run once the power has been turned on. If that is the case and the mechanism does not clear, then the belt is slipping and can't return the mechanism to a known start state. The unit will need to see a servicer to reset it and to replace the main drive belt.
Dan
Testimonial: "thanks for getting back i will mention this , cheers "
