CARTRIDGE PROBLEM TRI COLOR WONT PRINT
HTML clipboardHi
If your
printer has been left unused for some time? You probably have an ink clog
and the standard cleaning is not enough to clear the clogged ink.
Assuming your tri colour still has ink? (Empty they are about 30g Each 1g over that
is 1ml of unused ink.)
Provided it worked OK before a period of non-use? Then you just need to use a
PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon,
Epson HP and removing those horrible white lines which usually appear in
prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a little
Magic Inkjet Flush to soak the print head and you should be printing again
like new.
HTML clipboard
HTML clipboard
HTML clipboardYou can read more here:
How
to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP,
Lexmark, Dell, Olivetti etc…
Good Luck!
HTML clipboard
John P Bradley
Tinteiros (Ebay)
Tinteiros (Ebay)
