Washing Machines Logo
Posted on Jan 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer constantly fills with hot water even when turned off.
My washer will constantly fill with hot water even when it is not running. I have to turn the valve off to stop it. It will keep filling until it overflows. The cold water is fine.
  • Anonymous Mar 19, 2008
    Mine is cold water running in. I wonder if I connect old to hot and maybe put one of those things on there where water will mix before it goes into machine. Maybe that will work. Sure can't afford $50.
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Jan 03, 2008
Anonymous
Expert
Level 2:
Answers
51
Questions
0
Helped
61916
Points
116
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Washer fills with hot water even when unplugged
The freezing messed up the fill valve. This is the part that your hoses connect to on the back of the washer. Replace it and you will be fine.
1helpful
Cold water constantly runs even when the knob is pushed in to turn washer off.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
19helpful
2answers
Whirlpool Duet GHW9100LW1 fills up with power off
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
1helpful
Top load roper washer water will not cut off after filling machin
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at [email protected] Catriver..post back.
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Top Washing Machines Experts
john h
