Could be that the disk itself is incompatible with your friend's machine. Or your buddies machine may be starting to exhibit playback issues. Try another disk and see what happens.
Hi, I think the better task is (A) You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality! good luck
The latter part of your comments look familiar. Virgin Net did a similar thing and when the transmitters went to digital, all analogue recorders were rendered useless. All they could do is record the channel you are watching! Sign of the times I think!
With the assumption that this is a DVD recorder not just a player, and all connections are correct, two things need to be in place.
1. Source: the unit needs to have a cable tuner so you can receive a channel to record or an external input (look like stereo plugs) for video in and audio in so you can use a cable box for tuning a channel
2: Format: these units will need a DVD -R or DVD +R format blank to use. Some units can use both.
If this unit is a combo (DVDR and VCR in one box) then the source should be available to both for recording and selecting the appropriate channel should work. (Note if using the cable box then the recorder channel probably should be on 3 and set your cable box to the channel you want to record
Good luck.
i had to use the multiple delete on the first two recorded videos. the first one had a red dot on the screen. i could not delete the first video by itself.
The Philips DVDR 3505/37 has a built-in analog to Digital converter. No additional converter is needed. Just do the scan for over the air channels and set to go. Works fine now. [email protected]
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
This is very simple. you just have to remember to finalize the disc. doing this stops you making further recordings on the disk but allows you to play it in other devices. to finallize the disk. just go to the filalise disk option in the "top menu".
You have to hook up an AV cable from the box to the DVDR.. Out on the cable box to IN on the DVD player.
Then put your DVD player on AV1 - ( you can do this by pressing the INPUT SEL button on the DVDR remote)
Then put the Cable box on whatever channel you want to record. And press the record button on the DVDR and you will record whatever channel the cable box is on
If you can't get to AV1 then you have to disable cable box control (menu>setup>system>cable box control>off
