1) lube the deck belt,according the maintenance routing 2) lube the rollers bearing 3) measure the input voltage motor, if there are the motor need repair 4) measure the output voltage board, if there are NOT the board is faulty.see the block God bless you
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
You may have a beltand deck problem. Test by the following procedure: without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time.
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
This is usually caused by either a slipping drive belt or a broken front roller/drive pulley. Lower cover must be removed to tighten the drive belt. There are 4 screws located on the bottom of the unit that will release the cover.
