As the issue happens during sending and/or receiving of emails, the usual suspects are having a virus scanner installed which integrates itself with Outlook or having a corrupt srs-file
(srs stands for: Send Receive Setting).
The solutions in this case are quite easy;
Disable your virus scanner's integration with Outlook
This is a recommended procedure anyway, even when you don't have the error. For more background information about this see:
Disable virus scanner integration?
Reset your srs-file
The srs-file contains the settings that you set via the Send/Receive dialog in Outlook (CTRL+ALT+S). To reset it, simply rename it to .old when Outlook is closed. For more information and step-by-step instructions see:
Cannot Edit Send/Receive Settings
Also you can use these steps:
Go to C Drive> Program Files> Microsoft Office> Office 2007. After doing this you will see the PST files. Right click on it and go to the Properties and then select the Compatibility tab. Click on it to clear down all the Compatibility Mode Check Box. After doing so, click on Apply and then press OK. Restart the computer and your problem is sorted out.
If it useless use special tool.
See more:
http://www.oemailrecovery.com/outlook-recovery.html
Regards!
