? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
I unscrewed the panels on both sides of the tv to find out that the lamp was not turning on. What I did was I got my broom, tapped the lamp with it about 3 times when it was turned on, turned it off, tapped the lamp 3 more times, turned the tv on and it started working again.
Have you reset the lamp time after lamp replacement? If you wish to get more details, check this
site. Pull up older posts there. Check the site with patience, as it has over
2250 posts now. All are related to
electronic equipment repair help. Search
the site by 'Timeslide' option. It will
make search easy. Or, type in the brand
name to your device into its search box, and press "Enter"
1) test the power supply for shot and open in the transformer+coil +filter+diode+rectifier+,fuse blown replace with the same capacity!+c.breaker tripped , reset. 2) test the HV horizontal output short or defective + Flyback short or defective Horizontal output +125Vdc+Vertical output +80Vdc+12Vdc colors+12vdc all other circuit for to CRT. Remember the first thing do will have is RASTER. God bless you. see the block.d
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
