HP Color LaserJet CP3525x CC471AABA Printer Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Color LaserJet CP3525 68.X PERMANENT STORAGE WRITE FAIL
Anonymous
Level 2:
  • Expert 114 Answers
  • Posted on Nov 01, 2009
Anonymous
Expert
Level 2:
Answers
114
Questions
0
Helped
54996
Points
423
Perhaps this link may help you !
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=de&cc=de&taskId=125&prodSeriesId=74301&prodTypeId=18972&prodSeriesId=74301&objectID=bpl11648
1helpful
2answers
Why is there permanent storage init error?
web search HP laserjet printer error codes
1helpful
I accidentaly hit Chinese on hp laserjet pro 200 color M276n. How do I reset the printer so that I can try again?
Do a "Cold Reset" (http://bit.ly/17VI4hj): turn the printer off. Press the lower left corner of the screen while turning the printer on. Keep pressing (at least 30 seconds) until the screen show "Permanent storage init", then release.
1helpful
HP color laserjet 2605dn Hi, there is on display "replace supplies" with dot at black. The cartridge is nearly new, changed with a new one, but everytime still the same message. What´s the possibility...
Wolfgang,
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the select and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This should reset the printer
Al
[email protected]
7helpful
Logic card reset for hp color laserjet 1312 nfi mfp
1. Turn off the product.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
1helpful
Permanent Storage Write fail HP CP3525x problem no: 68
It appears that there is a problem with either the internal hardrive if you have this option installed, or the removeable Jet direct card if you have one installed, thirdly, it could be bad memory or the main board.
Go to HP's website and perform a firmware upgrade for your model if there is one.
I would first remove any add on option like networkcard, memory .... then turn the machine back on and see if the error goes away. You can also go through the menu and perform a fatory reset, this however in the process loose your IP address.
Onece you have aliminated the options I would move onto the main board or FIRMWARE
`permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
3helpful
HP laserjet 3330 Permanent Storage Init.
Switch of the printer press and hold down menu and cancel button turn on the printer keep holding these two buttons and turn on the printer.
As soon as printer display shows permanent storage init. release both the button.
Red color on hp 1600 not work fine
1. Turn off the printer.
2. Press and hold the (Select) and (Cancel Job) buttons simultaneously.
4. When you see the message Permanent storage init displays, release the (Select) and
(Cancel Job) buttons.
When the NVRAM init is complete, the printer will return to the Ready state.
k24674
Grand Canyon Tech
Grand Canyon Tech
