Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the reasion of error code c353 km bizhub model pls. assist in future precautions because my machine is new just 5 month ago purchased so iam in big trouble for that
Anonymous
Level 2:
  • Konica Minolta Expert 158 Answers
  • Posted on Nov 06, 2009
Anonymous
Level 2:
Answers
158
Questions
0
Helped
186215
Points
319
If you mean code c5353 this means cooling fan 2 motor has failed to turn. the fan motor will have to be replaced
Serial number need to be enterened KONICA C650
Notes:
1. When replacing the NVRAM or the EEPROM board, if the parts are replaced with used parts, the License Management error condition cannot be resolved by performing the repair operation.
In this scenario, Initialization would then be necessary and support must be contacted.
Additionally, if both the NVRAM and the EEPROM board are replaced, Initialization will be necessary.
IMPORTANT: Perform the Repair Procedure first, then the Initialize procedure. If initialization is required, collect the following information before calling support:
  • If i-Option was ever licensed on the MFP and if the additional 512MB of memory was ever installed at any time
  • The firmware level prior to the machine being upgraded to version 88 (bizhub C353 and bizhub C650 series models only)
  • If the machine ever had firmware version 85 or 86
  • A history of recent NVRAM or EEPROM board replacement
  • Obtain a machine Management List and have it ready to attach to the ticket.
  • A screenshot of the message returned from the LMS if "Repair" was unsuccessful
  • A "Request Code" from the MFP and the S/N must be obtained in order to start the "Initialization" procedure (see attached "Obtain Request Code" and "Initialize")
2. Make sure to enter the MFP Serial Number, Repair Demand Code and the Request Code in uppercase letters when entering data in License Management Server online.
3. Version 88 firmware refers to the bizhub C353 and bizhub C650 series models. Other models have the correct firmware from factory.
4. To view a PDF, you may need to download a free copy of Adobe Reader®.
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
PROBABLE CAUSES:
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
PARTS
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
PARTS
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
2helpful
2answers
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
C-5102 error in C353
Transport motor dealing with the duplexer which helps with making double side copies, your right side of the machine the cover has to opening outer open section is causing the problem check it and have a tech come out and check it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
C0202 bizhub c353
open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
KM Bizhub c353 touch screen
replace
1helpful
"konica minolta bizhub c353 error code c-4154"
"konica minolta bizhub c353 error code c-4154" help
change the chip and the imaging unit and still the same
what else I can do ??
help me please?
Thank you ...
Bizhub c353 code 2151 can't reset the code
Open the front door and close it.
Restart the machine.
Press utility/counter button and keep it pressed, now restart the machine.Do not release the button until the trouble reset option appear on the screen.Hit the trouble reset button then restart the machine.
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
