Sterling J3E Hamilton Antique Pocket Watch Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get my hamilton watch to open. I pulled out the wind knob and heard the click, but can't find any hinge or any other way to get it open. What am I doing wrong? Thanks
Anonymous
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on Nov 11, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
93
Questions
0
Helped
51119
Points
149
If your watches case does not have a hinge then pulling the crown out won't do anything but allow you to set the time if it is a stem set watch. If it is a lever set watch then the lever which is under the bezel will need to be pulled out before you can set the time.
On a pocket watch without a hinge the case back and or bezel will unscrew from the case.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
1helpful
How do I rewind my Rotary wrist watch?
just wind the knob
pulling the knob out changes the time
How to adjust the hands ?
I dont have that watch but on mine the knob usually used to wind the watch(my watch doesnt wind) pulls out one step to adjust the time, and then pulls out one more click to adjust the date. maybe try that.
How to remove adjustment knob on charisma kkg1928d
Open the watch case. Find the small hole or tiny piece of metal with the pointed groove next to the winding stem and push it with a needle or pointed tweezers. Pull out winding crown while still pushing.
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 • Watches
3helpful
Hamilton X-Copter Watch troubleshooting
Just pull it out to the second click/position and adjust time. When you unscrew the crown, it is in winding position, when you pull it out to the first click - it is in day/date adjusting position, when you pull it further out to the second click - it is in time setting position. In case if you do not have screw down crown, everything is the same, just you do not have to unscrew the crown. Rate me, plz.
2helpful
Watch is fully wind up but doesn't run?
Several solutions:
Needs cleaning is the best possible reason.
Broken balance due to being dropped is second.
r/
David
How do take off the knob that winds the hands on a wristwatch
The knob doesn't come off. It is attached to the stem, inside the watch. The only way to remove it, is to open the watch, pull the stem out, loosen the plate and move the pawl out of the way of the stem. If you ever want to use the watch again, it's best to have a jeweler or watchmaker do it.
Sep 10, 2009 • Watches
4helpful
Antique Hamilton pocket watch how to open? I unscrewed the face and see a notch at the bottom and a hinge on top of face. I tried prying upward at notch but it did not want to open. I was applying enough...
Pull the wind knob out...it takes a firm pull on mine. You will hear it click, then you have room to pull the movement out towards the hinge. Then close when done, and push the wind handle back in.
At one oclock the lever is pulled out about 1/4" then you can set the time, when finished, push the lever back in.
Hope this helps...george
2helpful
Brand New Rebel Pocket Watch How to Set
The pushbutton in the center of the winding crown is for watch case opening only. When you push it, the front lid should pop up, revealing the dial.
If you want to set the time, you have to pull out the winding crown (not the pushbutton) and adjust the hands to desired time. After setting the time push the crown back in and the watch is back in winding position.
Rate me, please.
Mar 23, 2009 • Watches
1helpful
Tag Heuer watch
The knob is a screw-cap seal. When closed (screwed in) it closes the chamber to prevent water from entering the watch.
You will need to unscrew it. It should snap out. In this position, you can wind the watch. Pull the knob out one click, and you can adjust the date. Pull the knob another one more click, and you can adjust the time.
Push the knob back in. In order to seal the watch back up, you will need to push the knob in while turning the knob. You will know you did it correctly when the knob will not turn any further.
Good luck.
Top Sterling Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sterling Watch Expert? Answer questions, earn points and help others
