Compaq Presario C700T Notebook Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to replace vista with xp, but When I tried to install os it is booting from cd but it is not recognising harddisk
Anonymous
Level 3:
President:
  • Master 2,600 Answers
  • Posted on Nov 01, 2009
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1018024
Points
8362
There are special partitions on the hard drive that are recovery partitions and they say what software can be and what will boot on the system. Since your laptop came with Vista, this partition has to be deleted for you to be able to use this disc on another computer or if you want to change the operating system to something else then what it came with from the factory. Below are the steps to take to enable this.
EISA Partition Delete
1. Open a command prompt as administrator.
2. Run Diskpart application by typing Diskpart in the command prompt.
3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
4. Then type in list disk and press Enter key to show all hard disk drive available.
5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
6. Type list partition and press Enter key to show all available and created partition in the disk selected.
7. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
8. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
ishaquekvm
Level 2:
Sergeant:
  • Expert 212 Answers
ishaquekvm
Expert
Level 2:
Sergeant:
Answers
212
Questions
0
Helped
59938
Points
541
Its because of sata hard disk
you have to download sata driver from the website
and copy in to one floppy
connect floppy in to the computer
during boot from the cd
press f6
select which version
follow installation steps
Anonymous
Level 1:
  • Contributor 74 Answers
Anonymous
Contributor
Level 1:
Answers
74
Questions
Helped
20326
Points
91
Hi follow instruction go to>cmos setting with F2 Or Delete then advance >IDE Configuration> set compatible then save settings and try
Invalid disk system will not leave screen
that error happens when you have a nonbooteable unit inserted or when your OS master boot record gets damage and the bios doesn't find the OS boot up loader.
check in the bios the boot order settings
usually is like this
1 - Floppy
2 - Cdrom
3 - HardDisk
4 - Network
there can be more options but those 4 are what we care now. change the order in what the system checks for a boot media
like this
1 - Cdrom
2 - Harddisk
=============== place any other device in any other after # 2
If you still get the message then make sure that you laptop has a OS installed ( if it has one already) then try to repair the MBR (master boot record) using the os install cd and the recovery console ( applies to Windows XP, Vista, 7 ).
Otherwise Install a operative system in the laptop and that should take care of the message.
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find...
If the BIOS cannot detect the hard drive, then it could faulty.
If this laptop is new, then it is still under warranty, take it back to the supplier for a warranty repair or a replacement.
If you try to repair it, you may void your warranty.
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
2answers
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
I can't downgrade Vista to Xp
You can install windows XP.
First go to BIOS and change sata mode to IDE mode
or option to disable SATA Native mode
then choose mode to IDE or disable SATA Native mode
then install windows XP
If there is no option about change sata mode in BIOS.
You should insert ahci driver to Windows XP CD using nLite
read this
http://komku.blogspot.com/2007/11/integrate-driver-into-windows.html
you can use this driver
http://cahya.prastyanto.googlepages.com/driver-sata-ahci-4920.zip
Or you can install windows by inserting driver when setup prompted
To install Windows XP with native SATA driver, perform the following steps:
Boot the notebook PC.
Insert the Windows XP installation CD into the optical CD/DVD drive.
Press the F6 key when prompted
Press the S key to specify the additional device.
Insert the SATA driver disk into drive A. (using floppy disk drive)
Follow the on-screen prompts.
Or if both way is cannot be done
i have the third way
use an unattended XP installation disk
you can download it from here:
http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
after you download
burn the CD image to the CD/DVD
then install XP using that CD/DVD
Hard disk not found on Dell
actually you cant install operating system. first u have to install lower version and then install higher version of os. install original operating system dont use pirated version
Installing Hitachi P7K500 Sata Hard Drive
YBC (/\)
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
110helpful
25answers
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
4answers
Compaq presario powers on but dont boot
RE INSTALL YOUR OS (LINUX OR WINDOWS OR VISTA ETC)
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
