Braun Tassimo Espresso Machine/Coffee Maker Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you still buy the braun energy cells that fit the braun 4 539 and if so, were?
Ned C Cook
Level 3:
President:
  • Master 3,433 Answers
  • Posted on Nov 01, 2009
Ned C Cook
Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1436824
Points
9966
Search the Web, type in Braun, model and energy cell. Something should return thatwill give you the resources you need.
My Braun type 4 507 will not ignite....I have full gas and it's hardly been used so what can I do
Best to contact the manufacturer for support and possible replacement.
The cleaning unit on my braun series 3 (350 cc-4)shaver will not work although it will charge after buying a new charging lead? Any ideas?
These cleaning systems are prone to many problems. If the shaver will charge directly from the cord but not the stand, your stand is faulty. They are not repairable since parts are not available. A new stand can be found at shaveroutlet.com if needed
Braun Clean Charge Base 5783 Fits Types 5772 5774
1helpful
I have bought a Braun epilator 7 , Braun type:5377 , in USA and have purchased the charger in the UK which is 100-240 v , do I still need to get a voltage converter to be able to use it in the UK ?
If the charger is 100 to 240VAC, it should work. USA use 110 volt so the charger should be OK with 240. The UK charger will probably have a UK 3 pin plug on it. If you use it in the US, you will have to change the plug again or buy an international adaptor which can be adapted to fit most outlets anywhere in the World.
I have a Braun 5525 rechargeable razor purchased in 1996. It no longer recharges, and in the charge window displays a jagged line rather than a battery image. Is this a problem with the internal cell, and...
In that case, the circuit board in also bad. This happens when the batteries aren't changed in a timely manner. You can buy a circuit board with batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
To open the shaver you will need to remove the two plastic screw covers on the bottom on either side of the port where the plug fits in. Then remove the screws underneath. The outer case will then slide off the bottom. You may need to reposition the travel lock to get it all the way of. Then unsnap the black plastic back of the inner case and remove it. You can then lift out the old circuit board. Reassemble in reverse order.
2answers
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
2helpful
2answers
Need replacement battery for braun Model number 5000-type 5724
Shaver Replacement Battery AA NiMh type
NiMh shaver battery pack with easy solder tabs, dimensions of battery are 1 11/16 length x 9/16 diameter. Battery is 1650 mAhWill fits several older model Braun shavers, $9.99. Contact http://shaveroutlet.com/ for detailed info. Older model Braun shaver batteries don't come on a circuit board and involve soldering.
Since I have never dissembled this model ask Shaver Outlet via e-mail if you buy the parts from them. They have been most helpful to me.
Braun espresso machine replacement part
If you are unable to get the part directly from BRAUN by calling 1-800-272-8611 (if your machine still falls within the warranty they will usually replace it for free) then I would recommend that you try Ebay as corny as it sounds because you could likely buy a used/new set for not much more than you would pay for the "ordered part" from replacement part sites.
Here's an example: http://cgi.ebay.com/VINTAGE-BRAUN-Coffee-Cappuccino-Maker-MODEL-3062_W0QQitemZ110253282082QQihZ001QQcategoryZ38252QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Also, if Braun no longer carries the part you need you could also try asking them if they have a diffuser from a different model that would work with your machine.
Good Luck!
2answers
Braun Blender MR500HC
We'll Match Any Authorized Dealers Price. Your Appliance Authority. www.AJMadison.com Or you may visit : Braun web site
Top Braun Coffee Makers & Espresso Machines Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
