A - upper left button
B - upper right button
C - down left button
D - down right button
In the Timekeeping mode, Precc C six times to enter to Hand Mode
Hold A until the current digital time start
Hold D to advance the analog time
If you like advance the analog time a long away, press D + B the same time. Press A to exit the setting screen.
To return to the Timekeeping mode press C
How to change time aw - 81
SOURCE: Casio watch
in time keeper mode (press lower left button 6 times) then hold down the top left button until the current digital timer starts blinking then hold down the lower right hand button until you see the minute hand start moving if you got a long way to go like more than 2 hours of adjusting press and hold the top right button and the bottom right button and the minute hand will move automatically. to stop the movement push the bottom right button and pressing this bottom right button advances the minute hand 20 seconds .. at a tick.
I hope this helps
SOURCE: How do i adjust the
push the mode button to the h-s mode, then hold down the adjust button for 3 second then you can adjust the hand by using the search button only
SOURCE: progaming instructions for Casio AW-81-7A
To set the Analog setting on a CASIO Ana-Digi AW81-7a...
1. Press the C button six times.
2. Hold the A button till the time flashes.
3. Press D button to advance the hands to desired time.
SOURCE: Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in
PDF format.
To download a PDF file, enter the four-digit (or three-digit)
module number marked on the back cover of your watch.
