There is a key for that, the one labeled [ln] for natural logarithm. For log in base 10 use the key [LOG]
[LN] 10 [ENTER] gives 2.302585093.
As you certainly know, you cannot take the logarithm of a negative number, nor of Zero.
Hope it helps.
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
SOURCE: how to calculate inverse of a 3x3 matrix in casio
Here is the solution for th FX-991ES.
The error may be due to the key you used to signifie
inverse. It says in the manual that you should use the key x^-1 not the
one used to input general powers.
Here is screen capture from the
Appendix to the manual. The picture shows the sequence of keys to press
to obtain the inverse of a 2x2 matrix. It is taken from page 41 of
Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
The link is for FX991ES. Look there foe you manual.
Hope it helps
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
SOURCE: can i calculate calculus using fx-991ms
If you want to get an answer like 1/2X for d/dx(X^2), you will have to
purchase a CAS calculator like Casio's Algebra FX-2 or Classpad. TI series calculators also have CAS.
However, you can calculate the numerical values of derivatives and integrals only.
To calculate the value of a proper integral:
for eg to calculate ∫xdx from 0 to 2, input as follows:
∫dx(X,0,2)
To calculate derivative at a point:
Example, to calculate d/dx X^2 at 3 input:
SHIFT+∫dx key X^2,3)
Display looks like this: d/dx(X^2,3).
