Yes it may very well be. Your battery may be running out. Try this: drain your battery completely than take it out of your laptop. Now power on your unit and let your computer recognize that the battery is missing. Turn off your unit and put in your battery and power up. Let the battery charge go to your battery cofig and check on the status. When it is fully charged you should get from 8 to 16 hours of constant battery time. When you jump back and forth from battery plug in your power cord and back and forth you actually wear your battery out faster. Sometime the life of the battery is cut in half. I disable my battery from my computer while it is still attached so you don't have to take it out and just use it when I need it. This will keep more refreshed and will last a lot longer.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Thanks for the response. It didn't work, but I don't think it was bad advice.
One thing I forgot to mention, the A/C adapter is new, but not a HP one. It's the correct watts/volts, but I am wondering if my husband maybe bought one that is not compatible. This just started the day we used the new adapter. And my laptop won't turn on with the adapter plugged into the wall without the battery, as you suggested.
Could it be the adapter or something more serious?
Thanks again!
im having the same exact situation new charger not hp and and laptop will not power on after leaving plugged in over night. worked perfectly the first day. the blue light up showing having power but will not turn on at all with out the battery and with the battery which is dead only flickers but wont turn in?
YOu were very helpful in finding a solution. It actually ended up being the motherboard, as it was singed (sp) right underneath the keyboard. We are waiting to get one so I don't know if that's the only issue.
Thanks!
