Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
Anonymous Posted on Oct 31, 2009
Slight shadow on part of screen
There is a slight shadow on the top right 1/4 of the screen, more obvious against a paler background but not so noticeable on darker. Never used to be there and now that it is I notice it all the time. Is this something that can be fixed? or something that happens these TV's through wear and tear? TV only 3 years old.
Todd Thornton
Level 2:
Scholar:
  • Expert 101 Answers
  • Posted on Oct 31, 2009
Todd Thornton
Expert
Level 2:
Scholar:
Answers
101
Questions
Helped
45566
Points
214
Hi, There have been several problems lately with the screens doing that. The only way is replacing the screen. I have located the problem causing it, It is the light filters in the panel,not replaceable at this time."pain in *** too"Did it from a broken panel. The light filters diffuse the light evenly so you do not notice the backlights. If you bend it,it will cause shadows like your getting. They heat up and swell a bit. And that is what is causing it. I have contacted Samsung,And Magnavox about the problem. Will not sell replacement light filter at this time tho.The LED backlit will not do this. They run cool.
If I can help you out more contact me at...
[email protected]
Testimonial: "Thanks very much for response, at least I know what it is now, will just have to live with it for a while and maybe get one of the led backlit sets."
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Screen refresh problem
Sometimes it is as simple as separating the wires behind the computer, so they are not touching. With the interference gone, all is fine.
Samsung 50in DLP HLT5076SX has what looks like a dark cloud against white background and white against black background about the size of a softball in the upper right area.
You could have Bad Light Engine causing this Problem these sets are well known for this , Call Encpmpass Parts for Price 1-800-638-3328
Slight shadow on right side of screen
this is image banding. the light tunnel needs to be adjusted, or replaced if it is collasped.
1helpful
I have a proxima dp6860 color shadow
the lcd panel may be out of alignment. there really isn't a way adjust it easily. it'll need to go in for repair to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Vertical strip paler than rest of the screen
Check connectore for that area, may be loose, release the cable before pulling, and reinstall it. See if that works.
2answers
Picture problem
Turn off the slow synchro function and the blurry on indoors with flash will stop.
Jan 02, 2008 • Cameras
Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
