The model number will be on the back of the tv. You'll have a model number serial number and a few other numbers. But for the price of a factory remote you can get a really nice universal....
You tv has two STK392-110 chips and replacement chip number STK394-160E can also be used. Click on above links to view chip image that will help you to locate in tv circuit board.
You can call Insignia parts at this number: 1-888-237-8289. Give them the model number of you television and they should be able to help you. Hope this helps you with your problem.
Please intimate exact model number of TV as KV36FS76Udoes not match with database. Click Remotes to see related remote number and price for your Sony TV if you found your TV model there.
remove front panel and check the 6 control knobs adjust the intensity of each color as well as the focus of the picture with those colors.be sure to mark the knobs so you can return them to there original position if the set shuts off. Good luck
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture
Replace IC (TDA8385J)
Sound but no picture
Check the LOT cable for short circuit
