SOURCE: forgot password for dvd parental
I had to mess with mine a little bit, but here is what I came up with.
1. Insert a DVD that you know will play without the need for parental control.
2. Play the movie like you were actually going to watch it.
3. Bring the movie to a "full stop" by either hitting O two (2) times or by bringing up the menu with SELECT and hit the stop button on the screen two (2) times. The following is an explanation: There are two versions of stop on the PS2. The first stop is more like pause only the screen will not have a picture. It will allow you to "stop" the movie and the resume when you are ready. The "full stop" that I mentioned means that you hit STOP a second time. If you hit play from here it will restart the movie entirely.
4. With the menu still up, look for the button directly above the PAUSE button that says SETUP and hit it.
5. If you go to the right two (2) times you will find the CUSTOM SETUP button. Hit it.
6. In this menu you will see the PARENTAL CONTROLS. This will light up in blue as long as the movie is in "FULL STOP." You will then move to the right and it will ask for your password.
7. Press SELECT and instead of saying enter password it will say delete password. Above this blue box will be numbers 0-9. Enter 7-4-4-4. The box should say password deleted and ask you to register a new password.
8. At this point you can enter anything you like, but I would advise using 0-0-0-0 that way if it asks again you can just press X four times and be done. However we are going to keep going and turn it off.
9. With a new password registered, move to where it says LEVEL and change this to off.
From this point forward you should be all set. For future reference, you can also go to http://www.us.playstation.com/Support/Manuals and using your SCPH number which will be found on the box or on the bottom of the Playstation itself you can find the manual to your machine and download it as a PDF for future use. I have also checked different manuals for different units for both the standard and slim versions and the code 7-4-4-4 seems to be universal. I realize that these instructions are also kind of lengthy but I wanted to make sure you had a step-by-step guide to fix your problem. I also didn't want you seem like an arrogant **** and just give you the website and tell you to check the manual. I hope this helps solve your problem.
SOURCE: Forgot Xbox 360 parental controlls password
they can either use the password reset answer or contact xbox live via the phone.http://support.xbox.com/support/en/us/nxe/contactus.aspx
good luck
