If the hard disk has failed, and you want the data off of the hard disk, you have two choices..
Purchase a extender to allow you to read the hard disk and also purchase a data recovery program to get the data off the hard disk...
Or google data recovery service and find one that can retrieve data of of bad hard drives..
Either way afterward you will need to purchase a new hard drive.. They have drives as low as 30 dollars online that can be purchased and then installed.
You will need to reinstall windows on the new hard drive you get..
Ultimately you will have to weigh the cost of repairing the computer ( purchasing a hardrive and purchasing a new copy of windows)
Versus purchasing a new computer.
SOURCE: Hi!My laptop (HP G7000)can not
Your hard disk has indeed failed, this is not an indication of a spyware problem. Your best bet, if the laptop is under warranty, is to contact HP for a replacement hard drive.
If, however, your are out of warranty or would prefer to do it yourself, it appears your laptop has a 2.5" SATA hard drive. You don't need a huge one, your failed hard drive was probably between 80-160GB. Do not get a hard drive with a PATA/IDE interface, or a 3.5" hard drive, as these will neither work nor fit in your computer.
There are several screws on the bottom of your laptop. You will not likely need to remove the entire laptop case, and many times the bottom of the laptop is labeled with icons or a description of the component beneath the panel in question. When you replace the hard drive, pay attention to the orientation of the old hard drive, as well as where any different size screws were placed.
Finally, you will need to restore your computer with a set of disks. As you will be replacing your hard drive, any restore partition that was previously on your computer will have been lost.
Please let me know if you have any other questions related to this issue. Thanks!
