Dell OptiPlex GX280 PC Desktop Logo
Anonymous Posted on Oct 30, 2009
Increase the amount of shared video dell gx280
How i can increase the amount of shared video memory on a dell optiplex gx280, i can saw only option for 1 or 8 MB in bios configuration and my pc (small form factor) has 2GB on ram?
Anonymous
Level 2:
  • Expert 63 Answers
  • Posted on Oct 30, 2009
Anonymous
Expert
Level 2:
Answers
63
Questions
Helped
14260
Points
189
Hello!
Don´t lose time for that, I think that you have integrated grafik in own chip, and they have same options with 1 or 64 MB, option in bios, that isn´t a standard shared grafik. Try AGP card if you have a socet for that.
Testimonial: "Thanks so much, i tried to buy a external video card."
Dell system gx280 bios A08, OS install, need to increase memory, can I do this?
and old DELL, GX280.
why post lacking what kind and size memory now? 1GB? 2GB?
or if replacing it all so it all matches.?
buy it on crucial.com> they know what it holds.
but you never told full name of PC>
first off it is and old OptiPlex. came with windows 2000 ,omg./
some sold 2005 year so is 14 years old,. today.
Any 3020 is far newer and better,.$50 cash easy .....
why mess with any 2005 PC?
this PC came in 3 sizes,
SFF, , small desktop and full desktop . what might yours be?
the motherboards are NOT THE SAME>
DDR2 memory it is.
400 & 533 MHz DDR2 SDRAM
when pC was new only 1GB sticks were max size.
4GB max but the SFF is 2GB max, see?
4 slots of DDR but 2 only on SFF
SFF = small form factor PC. dinky do case. ok>?tiny
what works can be hard, on old PCs
old PCs have very tricky memory density limits per stick.
ok?>
That is why buy from only a place that allows fast , simple
exchanges or refunds. ok?
RTM
https://www.dell.com/support/home/us/en/04/product-support/product/optiplex-gx280/manuals
Gta vc says (vc cannot find enough video memory)
Laptops have the video chip built-in on the motherboard and uses shared RAM (part of the main RAM).
You can increase the video RAM in the BIOS setting Video RAM but it will reduce the main RAM by the corresponding amount of memory.
If this is a problem then install more RAM in your laptop.
Upgrade graphics card memory
Most laptops have built-in video chip on the motherboard and they use shared RAM ie part of the main RAM.
To increase the video RAM go into the BIOS setting and then to video RAM to increase the amount of video RAM, this will also redusr the main RAM by the same amount.
You may wish to install more RAM in your laptop to give then laptop more memory.
The pc falls to sleep
Go into the Power Option in the Control Panel and increase the sleep or hibernate settings or set them to NEVER.
Click Start/Control Panel/Power Options and change the sleep or hibernate settings.
I have a dell 280GX and would like to increase it's graphics. I installed fsx deluxe but get out of range from monitor. I have done all the basics (settings advance and refresh). What is the suggestion?
This is a graphics card issue. I suggest you try say an Nvidia GTS250 card. If you are pushing up the resolution too high you will get this mesage. Short-term fix, try lowering the resolution in the settings of your current graphics card. This should help.
Dear Sir/Madam, i am using ASUS F-80Q laptop and the graphics is GMA x4500hd Gfx, it only shared 256mb memory, but i have seen about 1gb memory can this chip share (in fujitsu laptop)... there is no...
A BIOS firmware upgrade may allow the video RAM to be increased from 256Mb of RAM. Check the motherboard manufacturer's WEB site to see if this is possible.
Frequent message - virtural memory is low, increasing memory
Many times upgrading the ram amount will correct this problem. You may also upgrade you Video card for one that has a lot more memory chips(Total Ram) on it, since you have a desk top type computer. I have included a link in case you have misplaced you manual to see the original specifications. Ram and Video cards are available on line for such places as : Newegg.com               or            Tiger.com              to name two.
http://supportapj.dell.com/support/topics/topic.aspx/ap/shared/support/en/product_support_central?c=sg&l=en&s=gen&SystemID=PLX_PNT_CEL_GX270
3answers
2answers
Limited video shared memory 64mb
Hi icr
You better try to increase the virtual memory of your system as seems you would nt be able to increase the pre allocated video memory to your video device.
The virtual thing you can do by going to the my computer's properties and then in advanced tab you find performance options .Here you can tweak your virtual memory accg to your systtem memory
Waiting for your appreciation
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
