Typically when the seek buttons are omitted, Pressing and holding the previous/next track buttons you are referring to will provide a seek function. Try that and see if it works.
there's no function for this on mp3 players.if you know you're going to want to do this frequently when you're reading the book it would be better to download it in chapters and then you could at least jump from one chapter to another without listening to the whole thing each time.You could record chapters or the whole thing onto Audacity ( A free sound recording program) and break it up into smaller sections.This is a lot of messing about and you'd probably be better off trying to find the book as an ebook and just search out the relevant bit that you'd missed and read it instead.
I think it would be a great step forward if mp3 players were able to do this.The only equipment I know of that can do this(other than a media player on a pc) is on some digital radios where you can pause and do a rewind to the bit you want but this is usually only over a short period (5 mins for example on the Roberts digital radio.
hi katie. before you load your audio books onto you device try renaming each chapter to get them in order. your device should order them like your hard drive will
I use a Creative Zen V Plus, but have a similar problem.
First, an explanation: the issue is probably with the timecode in the audio track. This can happen when the audio file is created on a computer. The audiobook was likely "ripped" to a file from the original audiobook CD, and your player may not like the format the file is in. The best solution in this case is to recreate the audio files yourself. First remove all of the files from your Sansa for that particular book. Then use CD-burning software on your computer to create an audio CD (not a data CD!) from the files you got from the library. Finally, use the software that came with your Sansa to transfer the audio CD back to your Sansa. This way you know you are getting a correct format on your player.
If you have an additional issue (like me) where the tracks are too long and go back to the beginning every time you turn your player off, you may have to use an audio editor such as Audacity to chop the long tracks up into smaller tracks, but this is quite time consuming. It is best to acquire audiobooks in smaller tracks in the first place. This is the problem I have been faced with while using Audible.com to listen to audiobooks.
Reset All
This will reset the player to its original factory settings.
1. Press Menu to return to the Main Menu.
2. Move to Reset All and select it.
3. Select Save to reset to factory settings or Cancel to stop.
I have an e260. I use it for audiobooks a lot. I just press pause (centre top of the dial), and the track will resume from there next time (unless I go back to the main menu for radio of course.)
This player will only recognize Audible audiobook files
There is not a fix for the pause/resume issue - it is a major problem for just about every mp3 player that claims audiobook compatibility
Here are some help files: Audible 1) Adding audible books to your MP3 player using Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-add-book.wmv 2) Adding books from an online library to your computer using Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-add-books-from-online-library.wmv 3) Adding your MP3 player as a mobile device in Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-add-mobile-device.wmv 4) Deleting an audible book in your MP3 player using Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book.wmv 5) Deleting a book from your library using Audible Manager (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book-library.wmv 6) Purchasing an audible book from Audible.com (Windows XP) Windows - http://mp3support.sandisk.com/audible/xp-audible-purchase-book.wmv
