SOURCE: Casio DR-250HD calculator
The steps were mixed up a bit. This worked:
step 1 turn machine on
step 2 press and hold for two seconds the % button
step 3 input tax rate
step 4 press the tax+ button
SOURCE: Need user manual for Casio sl-200te
To change the tax rate, first press AC. Then press SET % for 2 seconds. Next, press TAX+, then enter the new or current tax rate. Enter the rate for a single digit tax rate such as 5% as 5, a single number; if you have a fractional percentage rate, such as 5.75%, enter it just that way: the 5, then a decimal and followed by 7& 5. Then press SET % again and you're done! I just did it on two of the calculators and it works. Hope this helps!
SOURCE: Lost manual for Casio DR 110S printig calculator.
You can call Casio @ 609-395-0154 and see if there is a download link for this calculator's manual.
Maybe they even send it to you.
Youll find your answer right here in the manual:
http://www.retrevo.com/support/Casio-DR-210TM-Calculators-manual/id/12440bh226/t/2/
800kb pdf file.
Hope this helps. Good luck!
kc
