Question about Krups KM7000
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
    Scholar:
  • 22 Answers
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Posted on Jan 31, 2010
  • dbrown900
    dbrown900 Apr 02, 2012
    You will also eventually burn out the hotplate element, which just happened to me. About a year and a half ago, I replaced the thermal fuses, and yesterday it stopped heating again. I was all set with spare thermal fusses, but they both checked good. While troubleshooting, I discovered that the hotplate element finally burned out. I was getting 120v across it, which tells me that it is open. You can get a new one that also comes with the thermal fuses for about $11, at www.goodmans.net for this model. Well worth it!
    New Friend:
I had this problem with my Krups FMF5 - 14 coffee pot. I would get an error that the water tank was empty, when it was actually full. Rather than a faulty water level sensor, the problem was two faulty Thermal Fuses at the bottom of the coffee pot.
To fix it I removed the bottom of the coffee maker (requires a torx security bit (http://www.jwestsales.com/product_images/p/826/torx_t10_security_tamper_proof_high_quality_1__14535_zoom.jpg) I used a small flat head screwdrive instead).
ALong side the warmer plate and heating unit there are two white plastic sleeves attached. Unclip the sleeves and slide them down the wire to expose the thermal fuses. I purchesed two new ones at Radio Shack for $3.50. Re-clamp the fuses and reinstall in the reverse order.
Posted on Oct 20, 2011
    New Friend:
Solution 1 is correct. See these sites for a DIY repair guide.
http://www.jimmysu.net/component/content/article/1-latest/971-oh-the-coffeemaker-is-broken-again
http://mark.koli.ch/2010/03/fixing-broken-krups-km7000-coffee-maker-triangle-head-tamper-proof-screws-too.html
Posted on Aug 25, 2010
  • bluemooning Aug 25, 2010
    Oops.. I meant the answer from SmallApplFix regarding the TCO fuses.
    New Friend:
  • 17 Answers
Your heating plate, is actually your water heater and is most likely failed. Krups replaced my whole unit.
Posted on Dec 22, 2009
SOURCE:
Where can I get a thermal fuse harness for a Krups mk7000
If it is no longer available why not read the temperature rating on your dead fuse and replace the fuse only?
Aug 18, 2014 | Krups KM7000 10 cup Grind and Brew coffee...
Krups KM7000 won't make a full pot.
I have one. there is a setting on how many cup you want 4,6,8,10, or 12 cups
Oct 18, 2012 | Krups KM7000 10 cup Grind and Brew coffee...
My Krups Grinder Brewer has stopped pulling water though the system. It just stays in the resevoir. Grinder part seems to be working fine.
Oct 09, 2009 | Krups KM7000
Krups KM7000 won't brew
Your heating plate is your hot water heater, and most likely failed. Krups replaced my whole unit.
Oct 07, 2009 | Krups Coffee Makers & Espresso Machines
KRUPS KM7000 POWER IS ON AND IT GRINDS BUT DOES NOT BREW THE WATER TO MAKE COFFEE.
Check to see if your heating plate warms up, if it doesn't then your water heater/heating plate has failed.
Oct 02, 2009 | Krups KM7000
Krups KM7000
Check to see if your heating plate heats up, if it doesn't then your water heater/heating plate has failed.
Sep 08, 2009 | Krups KM7000
Got a Krups KM7000. Coffee grinds but no water to brew coffee.Just clicks. then nothing. Tried to reset by unplugging but no help. Grinds everytime even when it's not supposed to. Water will not dispense.
This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heat on the plate and no dripping water.
Aug 24, 2009 | Krups Coffee Makers & Espresso Machines
Km7000 will not brew
Your heating plate/water heater has failed. Krups replace my whole unit.
Aug 15, 2009 | Krups KM7000
Water will not drop to make coffee....
I your plate is not heating, no water will flow. This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heating on the plate and no dripping water.
Jul 31, 2009 | Krups KM7000
Grinds but won't brew
If your plate is not heating, no water will flow. This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heat on the plate and no dripping water.
Jun 19, 2009 | Krups KM7000
Krups KM7000 Logo
2,794 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
