Excalibur Phantom Force Electronic Chess Set Logo
Posted on Oct 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to get the manual model 740D phantom force
Anonymous
Level 3:
President:
  • Master 625 Answers
  • Posted on Jan 22, 2010
Anonymous
Master
Level 3:
President:
Answers
625
Questions
0
Helped
344735
Points
1259
I had to find it too!
http://www.excaliburelectronics.com/images-manuals/Phantom%20Force%20Electronic%20Chess%20740D.pdf
  • Momchil Milev Oct 19, 2010
    Excalibur Electronics web-site (and company unfortunately) is gone... If you look for the manual - check here instead:http://www.chesshouse.com/v/vspfiles/man... Force Electronic Chess 740D.pdf
    Good luck, and Lord bless you!
2answers
Phantom force excalibur game not working
It is 14 years old, so the software is probably corrupt. See if you can contact the maker.
https://www.google.com/search?q=phantom+force+excalibur
I have a crossman phantom model cs1k77bv lost manual need to know where to put oil
Go to Crosman's web site for manuals:
http://www.crosman.com/cs/manuals/crosman-rifles
1helpful
Cleaner wont go . I cleaned the filter. and checked the cleaner for cloug .every thing seems ok.It wont go
whith the main pool pump on and the booster pump on too. pull the hose up to the deck, without pulling the phantom out of the water. You will see unions leaking, you will have to replace them. what is happening is pressure is being relieved from the unions and their for, does not have the force to move the phantom..
8helpful
2answers
Error Message MT01R
Fiddle around with the mechanism lock on the bottom. Once it engages properly, it will work. I had exactly the same problem.
1helpful
2answers
Motor for Akai GXC-740D Casette Deck
Hi pelagic
The motor is probably faulty. The heat is a give away for that. Many motors for older decks can still be sourced. Can you see what part numbers may be on the back plate of the motor and I can find a source for you. Awaiting your reply
regards
robotek
2answers
Missing key
Once back inside the temple, the first three floors will be basically the same,
with a few minor exceptions. When you get to B1, head up to the switch you
went to the first time, but instead of hitting it, bomb the rocks to the left
for a shortcut to the key. Grab it and run to the door, saving you a lot of
time.
For the second floor of the temple, you will still need to hit the two switches
to drop the key down, but instead of pulling the lever behind the Phantom, you
can bomb the wall directly south of the entrance for another shortcut. Grab
the key, then proceed the same way as the first time, through the blue and red
blocks. Head for the locked door, but this time stop at the safe zone for a
bit, and head just west of there and bomb the wall, revealing a 30 second bonus
to your Hourglass. Then you may proceed downstairs.
The third floor follows an almost identical procedure as the previous run.
First, grab the Force Shard in the northwest corner and take it to the
pedastal. Once that's taken care of, head east and bomb the rocks for an
additional 30 seconds. Then, head just south and use the Boomerang to hit the
switch, stopping the nearby spikes. Then, head to the southeast corner, grab
the second Force Shard and return to the pedastal. Now, instead of going to
hit the switch to lower the fires, you can use the shovel to reveal a rising
wind that will carry you to the top platform so that you can get the key.
Kill the Phantom, grab the key, and head to the locked door. Grab the last
Force Shard and return it to its pedastal, then proceed through to the next
room. Run to the far left side of the room, grab the 30 seconds, then head
back to the Door of Wisdom and proceed through and down the stairs.
Top Excalibur Games Experts
Marty Warge
luceysisa
luceysisa
Level 1 Expert
Are you an Excalibur Game Expert? Answer questions, earn points and help others
