Nikon D50 Digital Camera with 18-55mm Lens Logo
Anonymous Posted on Jan 02, 2008
D50 (CHR) problem, I think temperature related.
I recently used my Nikon D50 abroad it was working fine for about 20
pictures then I got a (CHR) flashing indicator. Then it worked again and
then same thing happened. The manual indicated a memory card problem however
I was using this camera in temperature of -9 C which although cold I wouldnt
have thought excessive. I kind of worked out that it would work for several
pictures when coming from hotel room to outside then I would get the (CHR)
indicator, assuming once the camera had cooled down. On one ocassion when it
stopped working I took it into a warm envirement and 10 minutes later it was
working ok again. On another ocassion I used it in a warmer enviroment and
it was ok with no problems.
I am therfore assuming its a temperature problem.
Can anyone throw any light on this or has anyone else experienced this? I
was using a freshly charged battery pack.
thanks
  • Anonymous Jun 02, 2008
    so what is here the soluttion??
  • Anonymous Mar 16, 2014
    Took pics, removed card, put in pc, downloaded pics. Inserted card back into D300. 2 weeks later, want to take pics, can't, CHR msg.
    Formatted card.....nothing.
    Removed battery, replaced, CHR still there.
    No pins bent, no damage to card. What can I do?
A
Anonymous
Its temperature related the barreries dont operate below 0 %
A
Anonymous
Hello the same problem...
what is it in final? Card problem?
1helpful
My D50 Nikon camera reads CHR I bought a new SD Card it is 4G can that to big
The D50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will only work with devices specifically designed to accept SDHC cards. The D50 wasn't. It only works with SD cards, 2GB and smaller.
D50 gets CHR blinking and will not take a picture. Have tried another chip but it is still CHR.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
2helpful
Flashes chr and won't fire
This can be caused by a badly connecting memory card, take it out and ensure its clean and connecting properly, also happens in cold climates, ensure the battery is fully charged. This is a comon problem with the D50
Memory Card Error
You have to format them in your camera for them to work. Formatting in other devices makes them useless. Stupid, but that's how it goes.
So, put a card in your camera, and find a format option in Your camera's menu. Everything will be fine after that.
And remember, any camera must first format the card for its own specifications before it can be used.
5helpful
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
No picture in the image screen
I suspect that you're looking for a "live view", like in the point & shoot cameras. Most DSLRs (like the Nikon D50) don't have live view. In other words, in order to see the picture you must take it first.
1helpful
Nikon d50
I have read some where that D50 takes upto 2GB only.
Vijay
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
